matt buz
errrrrr tyre size
hey all
Got some 15 inch estorils on my c and was going to order some tyres from performance alloys online.
http://www.performancealloys.com/home.asp
What size tyes do i need because if i go through the "choose tyres by car" link on the site its different to what i thought was written on the tyres currently on my car.
I am a bit of an amateur at this so forgive me.
Incidently I am off for some bridgestones and I am going to get my alloys polished. I saw a slammed golf with polished estorils on and i thought they looked awesome.
Cheers all
Matt BUz
195/50/15 is definately the right size.
And if you wanna get some ideas on what a Corrado lowered on polished Estorils looks like, look for info on Dave Bloomfields car on this forum. Its a black 16v which has had some tasteful bodywork done to it (removed side bump strips, rieger grille & eyebrow, etc) along with, of course, the polished estorils. Looks pukka :)
185/55/15 is the correct size but 99% of people use 195/50/15 as they are pretty much the same, plentiful and cheaper
I appreciate that the sizes are more-or-less comparable (putting 195/50/15 on a car set for 185/55/15 means the speedo will over read by 1.5%), but since the original VAG brochure and owners manual both say 195/50/15, I can only assume it was an offical design decision by VW to change to a more easily availble size...?
Do you have a source for this info?
DtM.
The Corrado was built, some of it by hand, in the Karmann Coachworks factory based in Osnabrück, Germany. The G60 stickered for just under $18,000 in 1990. The G60's last year was 1992, and it retailed for nearly $21,000 with the $725.00 sunroof option. The 1992 model did see a power increase of 11 more road HP (136 vs. 125) with the use of a larger crankshaft pulley. The odometer was digital also, a running change made in 1991. Tire size increased from 195/50R-15V to 205/50R-15V. Volkswagen never bothered to update their literature for the 1992 model year, as the phenomenal VR6 engine made its debut.
| Next |
right UK market C's are tyred as follows
1.8 16v.................185/55vr15
1.8 8v G60...........195/50vr15
2.0 8v...................dunno :oops: :oops:
2.0 16v.................195/50vr15
2.9 12v VR6.........205/50vr15
so coullstar you weren't far off
:wink:
