davidwort 0 Posted November 20, 2012 Are these vr6 mounts? Or is it a type of mount I've not seen over the years, might be an interesting replacement for the solid 02a bg mount? http://www.ebay.co.uk/itm/New-VW-Passat-mk3-mk4-1-9-TD-TDI-2-0-16v-rear-lower-engine-mount-RH-/321009102498?_trksid=p5197.m1997&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D16%26meid%3D3589777709919759583%26pid%3D100016%26prg%3D1006%26rk%3D4%26sd%3D281023335580%26 Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted November 20, 2012 Interesting. Not convinced it would fit though. The lower half looks quite wide/has a lip that the Rado/Golf mount doesn't have. Quote Share this post Link to post Share on other sites
Wullie 1 Posted November 21, 2012 If you put Corrado VR6 in the compatibility search thingy on the site is says it is not compatible. Quote Share this post Link to post Share on other sites
daleyboy 0 Posted November 21, 2012 Looks similar, the question is would it fit in the cup on the subframe. [ATTACH=CONFIG]70619[/ATTACH] Quote Share this post Link to post Share on other sites
