Oldtax
lurchy steering
whenever i start a journey the steering on my C seems a little lurchy! this only happens at slow speeds but all of a sudden for a split second it will want to veer left or right, and sometimes the steering will feel very light for a second or to. is it safe to drive and does anyone know whats wrong! :scratch:
thanks for any help
I had this issue about 6 months ago.
The bolts holding the ball joint into the wishbone had worked loose.
I would also check the condition of the ball joints and wishbone bushes as if they're worn it could have the same effect
oh dear. is that an expensive fix?! cheers
---------- Post added at 3:14 PM ---------- Previous post was at 2:23 PM ----------
from what i can see here http://the-corrado.net/archive/index.php?t-21998.html it looks like a pretty cheap and easy DIY fix (famous last words!)
so 3 Q's:
- will i need any special tools - about from splitter?
- how long can i drive for before this becomes serious?
- could it be anything else?
thanks for being so helpful mate
Check the condition of the aux drivebelt, tensioner and the pulleys, if the belt is slipping you'll get erratic steering. Slip the belt off and check all the bearings and security of the pulleys etc
It sounds serious now
All the jobs are pretty straight forward.
Couple of hours to change a wishbone being the longest. If bolts aren't seized.
I would get it looked at to be sure the correct part gets changed.
Are you running wide wheels? This can cause the same.
Or a loose power steering belt.
Many things to consider
oh no! im not confident i can do all those checks without a haynes!
do you guys know the approx. cost of getting this checked by an independant garage - doubt i could afford VW! or is that a case of how long is a piece of string.
thx again :notworthy:
Put your locacion in the side bar via your profile, then people can advise you where to take the car for any work needed, word of mouth beats yellow pages anyday
utter genius. hadnt thought of that. thx again.
still hoping its ball joints! im guessing VAG com wouldnt help in the slightest?! not that i can afford that!
If you're near Littlehampton then JMR (forum user 16vG60) is well regarded on here. Worth going there just to look at his car.
