daves16v
Bilstein Sport Shocks - VR6 Fitment - SOLD
Front and rear Bilstein sport shocks, covered 45k miles and 5 years old to fit VR6.
Receipts showing cost of £507.
They have some surface corrosion but nothing major, one of the hex sockets has been rounded off by me due to a stuck nut but has had a hex bolt head welded to the end so it can now be used again. You can see the extended end in the photo, this doesn't effect fitting and as you can see in the photos the nuts have been refitted.
They come with all mounting parts and top mounts, the front top bearings are in good condition as are the rubber mounts. You will need to buy bump stops for the rears as these fell apart when I disassembled them.
Photos show part numbers which I've googled but can't tell if the shocks are B6 or B8.
These were fitted with H&R lowering springs.
£80 collected please from M1 J25 Notts/Derbys area.
Any questions please ask.
Thanks
Dave
Edited by daves16v
Dave, would you consider posting? I know it'll be a hassle but don't mind the costs if you would? If so, I would def take these,
Cheers, Jamie
