cdem 0 Posted January 5, 2013 Just changing the selecter tower, cars a 1991 1,8 16v. Took the old one out but cant get the new one in. Tried re-fitting the old one too but it doesn't go. When re-fitting it doesnt go down enough and is about 1-2cm too high. Can anybody point out where i am going wrong? Quote Share this post Link to post Share on other sites
GrahamU 6 Posted January 5, 2013 Dont quote me, but I have heard you need to match the bottom bush aswell, the bush is on the underside of the gearbox with the VW emblem on it. Quote Share this post Link to post Share on other sites
dannyboy 0 Posted January 5, 2013 Their is a difference,look at my mk3 diesel gear thread and you'll see the difference http://the-corrado.net/showthread.php?58538-The-MK3-Diesel-Gearbox-Thread&highlight=diesel+gearbox+thread Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 5, 2013 (edited) Old one should just slot back, the early cars had narrower bottom bearings, that's where you need to match the shaft and the cap on the bottom of the box, the later wider ones have a vw logo on the bottom cap iirc, I have a thread somewhere on changing the towers and pics of about 4 different ones here you go: http://the-corrado.net/showthread.php?34328-changes-in-02A-selector-towers-and-shafts&highlight=Selector+tower Edited January 5, 2013 by davidwort Quote Share this post Link to post Share on other sites
cdem 0 Posted January 6, 2013 Old one doesn't slot in though and the car defiantly isn't in gear either. Have a spare box so swapping it over now. Shifter tower goes into that fine though which is odd. That thread is brilliant! Explains a lot :-) don't know why my search didn't bring it up. Quote Share this post Link to post Share on other sites
cdem 0 Posted January 7, 2013 I'm still not able to put the selector tower back in the box. Have ended up putting a new box on on Sunday and even with the box out I still can't fit the selector tower. It's defiantly not in gear or anything as I was able to push the car back to close the garage door so I'm lost for ideas! Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 7, 2013 Drain the oil and remove the bottom bush, see what's going on, I wonder if the forks are damaged somehow? Quote Share this post Link to post Share on other sites
cdem 0 Posted January 8, 2013 I can take the 2 bolts out to remove the bottom bush but it just doesnt seem to want to come off. I think i will take the box somewhere to be rebuilt, at least I know I will have a decent gearbox then. Gives me a reason to get the ABF rebuilt which is sat around in the garage :) Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 8, 2013 I can take the 2 bolts out to remove the bottom bush but it just doesnt seem to want to come off. I think i will take the box somewhere to be rebuilt, at least I know I will have a decent gearbox then. Gives me a reason to get the ABF rebuilt which is sat around in the garage :) They're also glued in place/sealer, you need to tap some of them round with a plastic mallet as the alloy cap is relatively soft Quote Share this post Link to post Share on other sites
