paddy26
Paddy26's Corrado Restoration
Thanks for the comments guys. I'm from Tipperary.
Not many updates since. I was away for a month and haven't had much time since I got back.
Before I left I got the battery temporarily connected and tested all electrics. When I connected to vag-com the only faults were related to sensors that I have deleted (n249, 112, sai, etc) so I was quite pleased with that. I also had a mate make up the brake hard-lines.
I now have the dash back in (hopefully for the final time) to check that all looms are long enough and in the correct place.
I need to decide now where I will install the side indicators and if I will run the wiring for cruise control. I'm also thinking of fitting an override switch for the rad fans, just as a precaution.
I'm working on the headliner at the moment and I'll try take a few pics when it's installed.
\Paddy
Can't believe its so long since I updated. It's probably because I had a nightmare with the headliner. I had it prepped easily enough, and since I had done a lot of carpeting in vans before I kind of took it as being a formality. Boy was I wrong. 3 tins of contact adhesive, 1 spray can of glue and and about 5m of suede later I was back where I started. I eventually changed for a different suede material with a foam backing and high temp glue and got it done 1st go.
Here it is installed.
As you can see I got a good bit done over the past 2 months.
Most of the interior is in and I had the glass fitted last week. I got new trim clips from ebay and the windscreen rubber kit from arz tuning.
The brake carriers should be here next week and I have sent the starter to get reconditioned(I don't have a vice yet and I couldn't open the screws on the solenoid.)
Once I have the starter back I will be ready to start the engine and see how my wiring is.
I sent the slam panel to the painters and have to collect it soon, along with the bumpers.
I also collected my scuttle panel(thanks slim_crx) and bought new mirror glass from ebay.
Thanks also to vw rule for the wiper linkage.
Here are a few pics I took this evening.
Thanks for the comments lads.
Not much of an update today. A parcel arrived today.
Out with the old:
And in with the new:
I'll have to make a new bench for it now.
\Paddy
The only thing I got done during the week is order a few more parts.
I'll be collecting the starter tomorrow morning and hope to get a chance to get the engine running.
I have the battery on charge and got this tonight in preparation:
I also bought this for the garage:
It doesn't look that big until I compare it to my old one:
Hopefully it'll be the last one I have to buy.
Here's hoping I'll have a real update tomorrow.
