lard44 0 Posted February 2, 2013 Hey all, Really chuffed with the vr6 I picked up this morning...but noticed on the long drive home that the temp barely touched 70 degrees, and when cruising at 2.5k less. The needle IS moving, and was fine on the test drive a week ago. Doing searches brings up two options...either a constantly open stat, or a faulty sender. Fan is blowing hot air after a couple of minutes as it should, does this help diagnosis? Cheers all, Quote Share this post Link to post Share on other sites
nrc 0 Posted February 2, 2013 The coolant gauge is controlled by the yellow temperature sender in the thermostat housing. Try removing the connector and giving both it and the sender a blast with WD40, see if that helps. Quote Share this post Link to post Share on other sites
seanl82 23 Posted February 2, 2013 Does it rise when in traffic or stood still? If it does, but drops down again when in motion it would point to a faulty stat. Quote Share this post Link to post Share on other sites
lard44 0 Posted February 2, 2013 Does it rise when in traffic or stood still? If it does, but drops down again when in motion it would point to a faulty stat. Yup, that's exactly what it does...right, looks like I'll be doing some shopping then... Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted February 2, 2013 Exactly the same as mine. Might change it tomorrow then. Just never got round to it. As everything else was ok Quote Share this post Link to post Share on other sites
P3rks 11 Posted February 2, 2013 Surely if your travelling at speed, on the motorway with low RPM, when it's freezing cold outside you'll get lower water temps because of all the cold air shooting over the radiator? Quote Share this post Link to post Share on other sites
Portent 0 Posted February 2, 2013 Only if the stat is faulty. I'd it's working correctly then it will close and keep the engine temp in the normal range. Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted February 2, 2013 Sounds like the same fault as I had, car takes a while to warm up and in traffic gets up to temp but on a run, sits just around 70. Way to tell if the stat is stuck open is the top rad pipe will start to get warm even when the engine hasn't warmed up. The thermostat is supped to keep the water in a closed loop around the engine and out of the radiator to help warming and then release to the rad once warm. Factor in changing your thermostat housing and other plastic pipes while in there as they get very brittle with age. You can get the lot from AVS for about £60, labour cost me £80 as I couldn't be arsed to do myself ;) Quote Share this post Link to post Share on other sites
Portent 0 Posted February 2, 2013 I need to change mine so plan on doing it in a few weeks when I do a coolant change. Thanks for the heads up on the housing (think most of my pipes have been replaced in the last few years). AVS? Do you have a link? Thanks. Quote Share this post Link to post Share on other sites
Hofmiester 10 Posted February 2, 2013 Sure http://www.vwspares.co.uk/ Quote Share this post Link to post Share on other sites
