timbreen
Vr6 wishbones and 16v wishbones
i have a vr6, but basically i have changed the set up, vr6 drive shaft into 16v boot, cv joints, hub, disks etc, but i have had to redrill the vr6 wishbone to fit 16v ball joint, would a 16v wishbone fit into the subframe? so i wouldn't need to redrill.
But you will be taking away the wide track ! Surely they was designed with that for a reason and changing its goin to effect the handling
Can you not do it any other way other than that it seems like a right farce just to get a wheel to fit , each to there own like but that seems like a lot of hard graft for some wheels
