p0l1wrath 10 Posted March 6, 2013 Hello, been having major difficulties with my abs light and keep coming across threads on the US forums where the ABS pump accumulator is always mentioned, and a pressure switch, do we have these on UK/RHD corrados? And if so where are they? Can't see them in the bay anywhere? I believe it's the black sphere object in the picture, but that's a LHD pump where the pump is under the reservoir. Cheers Quote Share this post Link to post Share on other sites
tony_ack 0 Posted March 6, 2013 I think the LHD and the RHD setup is completely different. What does Vagcom say? Quote Share this post Link to post Share on other sites
p0l1wrath 10 Posted March 6, 2013 (edited) Vagcom gave me nothing, changed front sensors resistance checked and clean up the rears, checked the fuse in the board and the fuses, relays and controller, passengers side, for mosture damage, and checked the relays work replaced the pump and bleed the system, only thing I can't be sure of now, is the controller, can you take these apart? And is that no on the accumulator? Cheers Edited March 7, 2013 by p0l1wrath Quote Share this post Link to post Share on other sites
buttles 0 Posted March 7, 2013 Have you changed the relays up in front of the glovebox? Or just checked them with an AVO? I have had various relays which 'checked out' but were proved faulty by new ones. It is an expense but takes one thing out of the failure loop. The UK VRs had Teaves 4 systems I think which are nothing like the picture you have up. Good luck in sorting this!! Quote Share this post Link to post Share on other sites
