robrado974 1 Posted March 30, 2013 I have looked in the manual , proberbly right in front of my face ! , claening isv again tomorrow and all electrics ,the stalling is getting worse and the revs keep going up and down . ive cleaned it out before , have new spark plugs , dizzy and hallsender ,cleaned all the ecu conections and other components . That was a while back ,so going to sort it tomorrow ,spose its worth checking vac hoses for small splits as well . The car has a great spark and no fuel worries . Rob Quote Share this post Link to post Share on other sites
dumptyboy 0 Posted March 30, 2013 (edited) isv damper. Throttle damper? Have you looked at the throttle position sensor aswell, as these can cause similar issues? And yes check for any split hoses. Edited March 30, 2013 by dumptyboy Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted March 30, 2013 Sounds like the ISV damper. It has black foam inside- check all of the pipes to make sure the foam hasn't been sucked in. Also check that all the pipes are connected securely and not split etc. Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 30, 2013 Will do guys , thanks as always , Rob . Quote Share this post Link to post Share on other sites
pbradley98 0 Posted March 30, 2013 Changing the ISV damper sorted similar stalling issues on mine, although ecm took a few runs to adapt to the new damper. Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 30, 2013 Still available from steelers then ? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted March 30, 2013 You can delete it by re-routing the hoses. Easy peasy! No ill-effects whatsoever. Quote Share this post Link to post Share on other sites
pbradley98 0 Posted March 30, 2013 Yep think it was about £55 a few months back... Quote Share this post Link to post Share on other sites
Dude VR6 0 Posted March 30, 2013 I had a back fire in the manifold and blew the throttle damper to bits, so re-rooted the pipe work to delete it. Seems to run fine without it. Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 31, 2013 Well i have cleaned everything , went out for a drive with robster r32 , went to get some fuel and it stalled 4 times ,revs all over the place . Then it settled down .roughly an hours drive and it was as sweet as a nut . Not sure whats going on ?. One thing that is suspect though is the fuel saver thats fitted , rob looked it up and its sposed to good for a few thousand mile , well its been on there for alot longer . Maybe its clogged ? Going to get some fuel pipe and get rid of it . The other thing she has started doing is not starting first time , the car has always started first turn of the key , now only fires second time round . Just wondering if its fuel starvation as the old fuel saver is clogged up . Regards ,Rob Quote Share this post Link to post Share on other sites
