VR6Pete
Passenger side late headlight glass surround + clip
Hi everyone.
I'm after the plastic surround from a passenger side late headlight glass and one metal securing clip.
Some one has drilled 2 holes in mine and I'm also missing one clip.
Cheers.
Pete
Cheers mate.
I've only noticed the other day that my passenger light is from an early corrado and my drivers is from a late, just going swap the glass and plastic surround like I have done with my drivers side already from a set of knackered lights I had.
Yes I have them, which clip do you need? Is it the one that holds the surround in just above the hole on your surround?
£10 + post, shall we say £13 posted?
Yeah that's the one Dave, the plastic bit on the surround just clips into it, there's 3 in total but already have 2.
But I'll take them off your hands for £13 no problem :)
I'm pretty sure you only need 2 clips, the centre tab doesn't have a clip, at least none of my Rado's did.
It's just the end one missing on one of mine, ill have check, I'm sure I've got 3 on my drivers side! Ill let you know :)
Yep. Your right Dave. Any chance you can send me a PM with payment details assuming all is ok with the bits?
