Tjninny 10 Posted April 16, 2013 Hi, I've removed both front wings, slam panel, crossmember and rad support to clean/paint and just wondered if I go one step further and remove my subframe, will the engine be ok supported by a beam across the wings? ie all the weight will be on the inner wings only. Cheers. Quote Share this post Link to post Share on other sites
Sean_Jaymo 0 Posted April 16, 2013 Yeah it'll be fine. I take it you want to use one of those cross engine bay lifts? Quote Share this post Link to post Share on other sites
KIPVW 0 Posted April 16, 2013 Yep did just this but left the wings in situ when i removed my vr subframe last year. Also wont do any harm to rest the engine on a few blocks too. Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted April 17, 2013 Kip did you not have the front X member in place though? Quote Share this post Link to post Share on other sites
KIPVW 0 Posted April 17, 2013 Cant remember :lol: I dont think so as it was all taken off to be coated so must have been off at the same time. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 17, 2013 I did mine with front bit in place. So still on the front mount. Then swapped and did the front with sub frame back on. ---------- Post added at 6:22 PM ---------- Previous post was at 6:20 PM ---------- Also found it really easy for the beam holding the engine to slip off the wings. Which it did do a few times. Quote Share this post Link to post Share on other sites
Tjninny 10 Posted April 17, 2013 Thanks for the info everybody - I think I'll play it safe and remove subframe with crossmember put back on. Quote Share this post Link to post Share on other sites
kevin55 10 Posted April 20, 2013 i think you have done well one of my friend also want to do like that i will advise him to remove the subframe. thanks for your information. Quote Share this post Link to post Share on other sites
