Jim Bowen
VR6 flywheel alignment.
Does the flywheel have to go on in a certain way. Noticed the marks on it and also a little line on the engine casing.
Taken flywheel off. But if I turn engine over now do I need to put flywheel back on first to keep the marks the same?
There's more than 5 holes. But think you are correct. Checked google and it shows one bolt is slightly off centre to the rest.
