robrado974
Urgent !! Rear panel needed
As above , I need the bit about 5'' or so , where the Vw badge sits . Anyone breaking , that is willing to cut this out for me ?
Rob
If you are cutting that area up, i could do with some to the left of the badge, say if the corrado script badge sat on the left hand side instead of right, it would be that area.
yep, i'm happy to do you a cut. Do you want to send me precise details of the piece you wan't?
Thanks mate , basically I had the rear end smoothed , two years later I'm going back to oem , they welded up the badge hole but its a bit messy to try ang cut the hole out for the badge to sit in . So the painter requires about 5" square around the badge section , so he can cut mine out and weld in the other piece . How much posted to Devon mate ? Rob
That's fine mate , PayPal ok? , pm me your details and I will sort it when I get home thanks Rob
