sexybourbon 0 Posted May 16, 2013 Last time i de catted the vr the pipe tended to sound quite tinny wen you planted your foot down , it wasnt blowing or anything like that , i was wondering if this time around before i put the decat in i could heat wrap it to deaded some of the tinny noise , only thing is im sure somewer i read that its not good for either the rest of the system or the de cat pipe , i cant remember wich one or if im even right and i didnt just read something different about exhausts , it wont effect the suitcase bix because there isnt one , the system will consist if standard downpipes and straight theough to a magnex back box Cheers Quote Share this post Link to post Share on other sites
coullstar 0 Posted May 16, 2013 Im pretty sure the CAT itself is what will reduce the tinny noise so wrapping it wont really do anything. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted May 16, 2013 Ive got a sports cat on the VR and it sounds tinny, like a sucking noise at low revs, disappears or cant be heard on high revs/speed. I had the same issue with a 6 branch manifold, the sound of the exhaust passing through the tubing caused a tinny sucking noise.. i did wrap it and it deadened it a little but only so much. Try it, got nothing to lose. Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted May 16, 2013 I think ill give it a go i just thought id read that it was bad for some part of the exhaust something to do with one part being hotter than the rest but i suppose the manifolds get wrapped and thats usualy the only part of the exhaust tjat gets wrapped in it Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted May 16, 2013 I think ill give it a go i just thought id read that it was bad for some part of the exhaust something to do with one part being hotter than the rest but i suppose the manifolds get wrapped and thats usualy the only part of the exhaust tjat gets wrapped in it Wrapping the cat itself would be a no no and wrapping cast iron manifolds would be bad as they would crack. Quote Share this post Link to post Share on other sites
