tony_ack 0 Posted May 19, 2013 I was investigating a leak around the aux water pump on my daily, and the bottom flange on the pump just sheared off. I've botched it up at the moment by removing the pump and putting the broken bit of flange between the pipes with a hose clip around them, but I'm not sure how long it will last. Has anyone got a spare pump with the bottom housing intact? Doesn't even matter if it doesn't work as long as the plastic at the bottom and the flanges are intact. Would be fantastic if someone has one in Sheffield or nearby. Cheers Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted May 19, 2013 Id be trawling ebay for breakers mate..... not sure if the golf ones are the same but this may make it easier to find Quote Share this post Link to post Share on other sites
tony_ack 0 Posted May 19, 2013 Cheers, good plan. I've just checked on ETKA and the same part no comes up on pretty much all 5/6 cylinder VWs up to about 2001, and quite a few SEATs too... should make it much easier to find. Quote Share this post Link to post Share on other sites
Dox 23 Posted May 19, 2013 Cheers, good plan. I've just checked on ETKA and the same part no comes up on pretty much all 5/6 cylinder VWs up to about 2001, and quite a few SEATs too... should make it much easier to find. I have one off a V5 20V but I think the plug is different? 10Vs are the same too ---------- Post added at 5:40 PM ---------- Previous post was at 5:28 PM ---------- http://s22.photobucket.com/user/penny318dog/media/IMAG0185_zps998936ef.jpg.html http://s22.photobucket.com/user/penny318dog/media/IMAG0184_zps1ef3092b.jpg.html Quote Share this post Link to post Share on other sites
tony_ack 0 Posted May 21, 2013 Hi Dox, it's definitely a different plug as the VR one is square. I could swap the bottom housings over, but it would really depend on how much you wanted for it? Quote Share this post Link to post Share on other sites
robo22sri 10 Posted May 21, 2013 Just do a delete make up some copper pipe to get you out of a jiffy :) Quote Share this post Link to post Share on other sites
Dox 23 Posted May 21, 2013 Or fit a wiring plug off a MK4 based car (small spade connectors fit perfectly anyway)? Its tested and working, it has pos and neg markings by the socket. Make me an offer that's fair to us both and I can post it on Friday Quote Share this post Link to post Share on other sites
tony_ack 0 Posted May 22, 2013 Dox = I've sent a PM The temporary solution is holding up pretty well so far - no leaks at all and the smell of coolant under the bonnet has completely gone fort he first time since I've owned the car! Quote Share this post Link to post Share on other sites
Dox 23 Posted May 24, 2013 I posted this at mid day, postage details and tracking barcode sent via PM Thanks Quote Share this post Link to post Share on other sites
