Timbo
94 LA9V VR6 - New cylinder head and SP263 cams
I've been around for ages, but never made a thread for my car. Here it is!
(It might be easier to view the pictures on imgur.com).
In 2010 thieving *******s stole my car and messed up the fuel filler (I blame them for the rust too ;)):
Oh dear:
Pizza box template:
Cutty, bendy, hammery, weldy, grindy:
v69coJsm.jpg CgTJt7Jm.jpg qhyu2WMm.jpg Jj1MWbRm.jpg LTpcHnym.jpg UCEuXlem.jpg 56jRzxhm.jpg n7t1SPQm.jpg
Chopping it up so it fits:
Welding it in:
Edited by Timbo
More welding:
The scary bit:
Convincing the donor panel to fit:
It got too wet and windy to weld outside, so I put a tent over my car :D:
Fuel filler mechanism upgrade:
Primer and welding (I found a use for the stupid big welding clamp I didn't think I'd use):
2XUvI9Fm.jpg 8MjjUN8m.jpg Ddh16LXm.jpg vN3KUKwm.jpg nLhL0MMm.jpg 9HKAUfHm.jpg AY5Qcy5m.jpg 3AyO9KRm.jpg
Still a bit crooked, but nothing a skim of filler won't sort:
Edited by Timbo
Got some etch primer on it to stop it rusting before the paint stripping began:
Tail gate number plate light repair:
3ElNllCm.jpg Bsz7m3um.jpg PGl578tm.jpg V8eYlsxm.jpg RFch0Rqm.jpg noRNwDom.jpg rkk1vmSm.jpg HuG5WVnm.jpg ikH7dEkm.jpg v34xUACm.jpg TZRBocDm.jpg 6ZVEgHem.jpg
Paint stripping (also, tiny weld penis):
Filler:
Edited by Timbo
I didn't take many pictures around this time as I was getting pretty ****ed off with the whole thing; especially when I uncovered this:
Some time later, when the shell came back from the body shop:
I made a new fuel filler lock thing out of stainless:
Starting to look like a car again:
Woo, all back together:
My advice: if you're thinking about respraying a car. Just. Say. No. Having said that, it looks pretty nice now :D.
Edited by Timbo
Great skills with the fabrication and welding there!! I wish I'd had access to pics like that when fixing my fuel filler.
Thanks! I always wanted to learn how to weld and this was a good project for that. Also, I made the thumbnails a bit bigger.
I just looked at your thread. That filler is a bar steward huh? All the Corrados I've seen have the same thing. I think it's basically just a lack of sealer around the wee plastic grommets that the filler lock cover screws into. Having said that, it's a nice little mud trap up behind the filler neck. I've had thoughts about fabbing up a panel that would sit over the filler neck to deflect all the crap that gets flicked up there. i.e a sort of minimal arch liner for that side only that mounted using the fuel tank neck bolts. The design would be pretty critical though as you risk just making the problem worse if it didn't drain properly.
So I finally got around to fitting my 312mm brakes. I'm pretty pleased; the pedal is still nice and solid and the extra stopping power only really comes in when you stand on them. I was a little concerned they'd be annoyingly strong. I also fabbed up some splash guards out of stainless sheet. I tried to make them resemble the OEM splash guards to some extent:
yep they'll all get this at some stage, ticking time bomb for most owners. you really did a great job with those panels, makes my efforts looks proper agricultural!
Great work indeed...............When will i drop my car off? :lol:
Right after I finish mine? Probably about 2017...
I couldn't tell you to be honest. I did all the welding, filling and prep, but left the painting to somebody who knows what they're doing. I assume it's some kind of Schutz spray, but I don't know exactly what...
Yep, that job. It's pretty satisfying to get it done. I might be imagining it but it feels like I've recovered a bit of power, is that possible? I guess the chains could potentially stretch enough to put the timing out. I also changed the clutch since the old one had a good soaking in brake fluid when my slave cylinder failed. Perhaps it was slipping under power? Anyway, pretty pleased to have a nice quiet engine.
awesome work timbo ;)
going back to your bodywork, what did you use for the sills to give them the texture?
upol gravitex , you need to apply it using a stone chip gun via air compressor at around 50psi
  • Like 1
Thanks, gonna need some of this soon
