J-ME 10 Posted June 6, 2013 I've come to find out it comes on at around 50, at either neutral or negative throttle, before I have turned the ignition switch off and on again, but tonight I tried sticking clutch in and giving it a rev and it stopped, any one know why it would do this? It's a 91 1.8 valver rado Quote Share this post Link to post Share on other sites
easypops 8 Posted June 7, 2013 Fairly sure it's a low oil indicator?, usually comes on if your level is low and you go round a corner, pushing oil to one side. Check your oil :) Quote Share this post Link to post Share on other sites
J-ME 10 Posted June 7, 2013 I had topped it up not 15 mins before hand I can drive it all through the week no problems but as soon as I go in a run it goes bananas, if it was a low level it wouldn't go off when I revved it, could it be the sensors? Quote Share this post Link to post Share on other sites
easypops 8 Posted June 7, 2013 You'll need to wait until someone with proper knowledge looks in as I can't answer that . Good luck :) Quote Share this post Link to post Share on other sites
