'Rado_TDI
Another TDI!
Then rims got some loving after I hit a pot hole
God they are horrible these pretend wheels
Didn't think there was much point in putting new plastic bolts back in lol
Then a fluid change! :scratch:
It was being well used, then this happened :(
luckily the little ****ers were foiled by the antitheft devices :)
So that mean the old girl was parked up for a bit.... which meant the ongoing window leaky problem I had manifested....
Turned out somebody didn't put any sealant in when they put the screen in!!!!
So then I pulled every thing out to dry and seal it all once and for all.
Blasted the windscreen surround to get rid of the nasty pitted bits
few places had gone though, which I have welded new steel into, before epoxying.
uuugh bonnet all flatted back, think that took 6-7h :bh
quick jizz of epoxy mastic to protect / seal
few other wee spots of previously poor prep blasted and a weird chip in the roof too
troublesome little patch here- didn't really want to take the window out so sprayed that with a little sand too - not brilliant though
some more rot
needs a bit of patching but with the speed blasted metal rusts at I painted it for now, along with two scabby bits on the boot
Wheel arches & subframe next!
Should really have done this in the project section lol
If any admin reads this, please can you move to "members motors"?
Cheers!
Been plodding along
****e old VWs :(
At that point I dropped the beam as I wanted to give it a little love. I've been meaning to disassemble the brakes and lube them up for ages so it sort of seemed a good time
Also, after some **** nuggets changed some brake lines, the rear passenger brake wasn't working properly and I couldn't bleed it :i_dont_kn
I did have the rear wheel bearings done on my last MOT..... so I guess somebody has already had the carrier bolts off, but much to my suprise I found this
Kind of glad I did drop the axle as I also found this!
Edited by 'Rado_TDI
A load more warfare later
Fresh powder coat all successfully removed and new bushes ruined....
Trying to remember how I installed rear bearings last time, as this time they seem much trickier lol :bh:
Really must buy a Press.
Very dull goings on, but the end is in sight for the Driver side arch!
Been chipping away a little at a time...
Both the front and the back were a bit holey in the traditional VW place
Been having a bit of a head scratch about the fuel flap lock part - not very easy to get to!
Couple more repair patches and that side is done
When one VW lives on, another dies lol
Next is the passenger arch which is much tidier, just a little rot... in the usual place
Been battering on Bilt Hamber rust convertor where I can, next will be epoxy mastic, seam sealer and lots of gravitex.
Both arches almost welded! I feel its a significant achievement as it has felt like it has taken about 10years !
I also swapped these over, so that's another stupid but useful job done :)
Anyway, some uninteresting pics of the bottom of the 'Rado of Dailyness...
Epoxy mastic
Nearly a litre of seam sealer :D
Then a bit of gravitex
Goodbye wiper
Few more pics now the rear bit is sort of better, been looking at the front bit. Nothing much to report...
Was a little concerned about my wings rotting inside, well the lip any way - it's a bit cracked after an "emergency" baseball bat roll, plus I wanted to get the door shuts tidy (pet hate) so I bit the bullet and pulled them off
only real concern is where some **** has ****ted up this with a jack :bh
looks fun to fix....
12 degree's +/- 2 dialed.
was getting a bit bored with having molten steel drip on me so tackled a couple of small jobs for a break...
Goodbye 02A shifter, hello, 02J - the 02A was really slack and that used to make more noise shaking about than the engine! Actually, I think that the seal in the to might have been shot judging by the crusty brown gunge....
so while that was off, switched this over
I had to hack up the underneath of the car a bit to get the 02J shift tower in but it's there bar some bolts, which I didn't have. Feels awesome!
So back to body work, I previously rolled my arches which went OK, except this bit
which as you can see looks suspect & lumpy... so I hit the lump out....
LOL
Then back to this jacking point
Which I found an ideal double skinned bit on the MK4's bonnet
So I haphazardly pigeon ****ted it in, god I hate welding upsidedown
and a sploge of bilt hamber
Have you fitted the pump on the left? What's wrong with the Pierberg? pump on the right?
Edited by Dox
My TDI has a sexy clattery diesel pump up front so I dont need the feeble little fuel pump - Which unfortunately didn't work so when I got to 1/4 of a tank I'd suck air and run out of fuel heehee :scratch:
The other pick up has pipes that go to the bottom of the tank with no breaks :)
fantastic work as usual and a generally entertaining thread! Your mechanical abilities are really impressive.
Cheers Fla, glad you enjoyed the read so far :)
Porsche brakes to slow the added diseaseil weight, or insane performance upgrade, or just to look nice, depending how full of camber you think I am...:camp:
More chipping away - but the stuff I've been doing barely warrants a picture... we all know those jobs....
Equal bit of MK4 bonnet fitted for rust - delete
Got some P40!!
all I need are some wood screws to hold in the mech and job's a good un :p
....the fun continues with more rot repair
Blobbed in along with a new strip down the front
and a nice thick blob of weld down the crease, just in case lol
and bilt hamber for good measure
Doors off
Prep of some kind.... big thanks to whoever covered everything in silicon sealant. :cowboy:
Fancy pants new door stand from some rubbish I sound behind my house.... didn't measure it very well LOL
Think it may have been scaffolding, but it was so weak, would have been scary to climb
Always wondered why the electric mirrors didn't work...
moar "prep"
Mine does the same, I was hoping you swirl pot was intact but your pump faulty
TBH I never actually checked, just bunged the lot out :thumbleft:
Lol I didn't realise I hadn't updated this in a while!
So, I wanted something to regret doing, so I did this high danger manoeuvre.....
plastic primer is weird....
and also reacted to **** up my hi-build which makes me sad.
Annoyingly, My initial intention was to colour code my handles, but I seem to have forgotten to include them in the priming :bh
Why am I doing this? I noticed that some new VWs and Audis have gloss plastics therefore in the interest of science, I'm testing the realms of fail.....
Well that and my plastics are all cracked to fcuk, or covered in overspray :bh
moooooooooooooooooore sanded bits, chilling in the kitchen awaiting primer tonight I hope :)
De-fillered and dent bashed out in preparation for refilling :rolleyes:
and a bit of ye old nail technique
could do with some more epoxy mastic.... but also some more finances to enable that :bh
So hopefully that the last of the sketchy bits sorted out now - both rear windows had some bubbles - well I noticed the drivers side after it was lovingly smashed bu some little chavs last year, so I chopped them both back out to sort it out. Passenger side was alright really :rolleyes:
bit of bilt hamber
and ye olde epoxy
I haven't really finished the arch tidy project I was undertaking (way out of my depth here really) but I had loads of epoxy left so jizzed a bit on to slow the rot coming back
2cm less filler this time :D
Continuing the sleep inducing update-ness
When I emptied the rubbish from the boot, I forgot that I had sort of made a board and sub box, so here's a pic of them too :D
Was hoping to complete my priming during this session, but when I reached for the spare tin of hi-build, it turned out to be lacquer :cuckoo: :ignore:
still got a wee bit sprayed up - I left the smallest remnant of the frigging yellow paint that I was trying to remove, and hey ho - that bit reacted :bh
The slam panel looked immaculate from the top except one bubble which I poked at with a screwdriver... not good. So have pulled the panel seeing as it was only a couple of bolts and given a quick rust address, oh and of course, last time I changed the aux belt, like a moron I slipped and bent the top of the panel :(
then tying to use my space effectively - some panel mounts out of some **** steel rubbish
and despite having a 5 year qualification in concrete mixing, I am incredibly poor at it... 'spose that sums up most of life thought - paper vs. actual experience
but hopefully they'll be strong enough for my new work/painting lamps... :scratch:
Well its nice and light in my wee shed now - 14 6ft "daylight" tubes now sorted!
Need to complete painting the walls and floor!!
Dunno how much more un-exiting pics like this can get. Kept finding things that I wasn't happy with :bh
Ventilation was my next project, no actually I had to refit my WC over Christmas so that put things on hold for a while :sad:
Actually.... then I pulled my hubs to bits
Look at that, all screws and heads intact!
New toy....? ahhh! glorious press!
Investment in proper tools - took about 20 seconds to do each side with no damage, swearing, bashed or cut fingers. Glorious.
Been talking about a press for about 10 years, wish I'd got one 10 years ago!
So since all that this happened;
brrr
....brrrrr
I did silver, blue, blue, clear, clear
I used 5 litres of blue (1:1) I hope its covered, though there was a baldy bit on the bumper :(
Haven't inspected the laquer - will do it when I feel brave enough
My appalling attempt at prep and fat arse were the biggest problems so far :bh
