Jim Bowen 1 Posted June 25, 2013 Is there a way to check for wear on the other parts of engine that aren't the head? My engine i've removed had 201,000miles on it, am rebuilding the head, but wondering if its worth doing anything with the pistons or the crank bit or if there are ways to check these things? I don't really know what i'm looking for. If it is worn or in need of work, what are the likely things i'd need to get done? ---------- Post added at 3:11 PM ---------- Previous post was at 3:07 PM ---------- Seen this on ebay http://www.ebay.co.uk/itm/151061973308?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 Its a 2.8 AAA Block and pistons "This is for 1 x Bare Brand new Volkswagen Block / 6 x Brand New Pistons Rings and pins ./ Circlips . There is no Crankshaft or Rods" Its £580. What i'm wondering is, can i fit my corrado parts to this, like the head and inlet, even the crank, so basically making it a 2.8 corrado engine. Is the price good? I have no idea what it might cost to rebuild my 2.9 version. Don't mind doing the head, but thought i heard pistons etc were expensive. Quote Share this post Link to post Share on other sites
tony_ack 0 Posted June 25, 2013 Yep, you can check the bores to see what sort of condition the bottom end is in. Lip - if there is a noticable lip then you should re-bore if you want to keep your current block, and this may mean needing oversize pistons Glaze - check the bores and see how shiny they are. If there are no hone marks, then you could do with re-honing the bores. You should be able to rebuild the block with the original pistons, assuming they're not pitted. Whether you need a re-hone or not, it makes sense to fit new piston rings while the engine is stripped down. I've heard that 2.9 engines can ovalise bores 1 and 6, but I'm not sure how you'd check for that, or whether that would be visible. It'd make sense to replace the bottom end bearings too, and possibly the oil pump if it's never been done and you're planning to do another 200000 miles. Quote Share this post Link to post Share on other sites
aide 0 Posted June 26, 2013 You need a dial bore indicator to check for oval cylinders, not too expensive and handy bit of kit for checking end float and suchlike. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 26, 2013 Just drop a 24V in mate, and then all your noise and wear issues will be dealt with in one fell swoop :D Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 26, 2013 But then i have to find a decent 24v that i trust, or rebuild one, Plus all the extra wiring and stuff, think i'd rather stick with the 12v for now, has been decent enough for the last 7yrs Quote Share this post Link to post Share on other sites
Jim 2 Posted June 26, 2013 Plus if you're like me there's a certain determination to keep the 12 valve VR6 for originality, etc. I appreciate the 24V is a better engine in just about every way - but I feel an affinity for, and a draw towards keeping the engine relatively original. Even if it will cost more in the long term. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 26, 2013 Then stop whinging about noises and accept it for what it is ;) Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 26, 2013 Am sure its not meant to be as noisy as it is, got a new noise now as well when i start it, more knocky, like knocking two bits of hardwood together, but it goes away. Am sure my old engine sounded ok from 130,000miles to 194,000miles Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 26, 2013 You mean knocking oak onto mahogany or pine onto cedar? If it's a walnut onto birch noise, get a new engine mate! Well, the VR6 has a repetoire of noises to call upon. Piston slap, small end knock, oil pump whine, injector tick, worn chain noise and cam / tappet noise. None of them are serious. More of an irritation than a significant problem. At 200K, I'd be inclinded to replacing it with a younger one anyway, or rebuilding. At 200K Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted June 26, 2013 You mean knocking oak onto mahogany or pine onto cedar? If it's a walnut onto birch noise, get a new engine mate! Should've been called a Corrado TreeR6. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 26, 2013 Wood is under rated as a diagnostic tool! Quote Share this post Link to post Share on other sites
Vw.bones 10 Posted June 26, 2013 Always found using wood a great tool .. Especially in the mornings 😜😜😜😜😜😜 Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 26, 2013 Aye! Why is wood woodier than normal in the mornings??! Quote Share this post Link to post Share on other sites
