sexybourbon
slightly bad running , changing sensors and other parts , advice
Hi all my vr is running slightly bad from cold and doesent seem to be "quite right" and was just after a bit of advise on what is best to change , im hoing to the natiaonal day so want it done before then , its quite a trek and i font want any problems
So far i want to change the coil pack , iv put a wanted add up or i can get one from ecp
I was thinking of changing for new the below parts
Lambda probe , iv already got a brand new beru one to go on
Coilpack
Blue temp sensor
Intake air sensor
Oil temp sensor
Spark plugs
What else would you change while at it , it gets regular oil changes with synta silver and oil filter
And its runn off 99ron fuel
Thanks
Matt
Well .. the only time mine has run rough when cold it was the coil pack..
Though I'm sure if the engine hasn't got a good feed on the temperature it'll run rough all the time.
Cheers for the replys ill get a vw blue temp sensor , iv rang and there 20 quid
Vw want 350 for a coilpack
Iv rang ecp and pages and they eang from 95 to 195 quid
One was a bremi one and one was bosch
I was looking at soending around 100 wuid on one depending on wat was an ok part to use
Does anyone know wers best to get one
Can't remember where you get the Beru one from, but mine has lasted years and happy with it, also using the Beru leads. Might of been from GSF
Cheers jim iv opted for a beru one , my leads are pretty new and all look in good nik for now
Right so far i have bought
Beru coilpack
New beru lambda probe
Genuine blue temp sensor
X6 ngk spark plugs , nothing fancy , following advice from a post from kevhaywire
I want to replace the maf but cant find a decent one anywer ? Anyone got a decent link
Also going to order some motul x cess 8100 oil on payday and give that a try
I also want to order the ford galaxy v6 pcv valve for oeace of mind , does anyone have a part number or can i just state the part and they will know even if i say its for a corrado
Is there anything else worth changing while im at it ? Or is that about it , i was going to change the manifold intake sensor for oeace of mind but im pretty confident its ok tbh
