sam2.0 10 Posted July 26, 2013 This fault has developed over the last month. Basically, when going over a speed bump or a small pot hole, I get a tinny metallic 'clanging' noise from the front end. It can be either wheel, but they both make very similar noises. I also suspect this issue is causing the car to handle badly, its not what it was. I've had the car up and there isn't any movement when moving the wheels, and I can't see anything lose underneath it. I did notice this though (pic). Could this be it? Anything else I need to check? Car is a '95 2.0 16v [ATTACH]75133[/ATTACH] Quote Share this post Link to post Share on other sites
davidwort 0 Posted July 26, 2013 downpipe or cat heat shield loose? Quote Share this post Link to post Share on other sites
carrots 1 Posted July 26, 2013 that drop link dont look to good,i would change them both even if you find its not that Quote Share this post Link to post Share on other sites
sam2.0 10 Posted July 26, 2013 The car doesn't feel as good as it did when I bought it, in the twisties. Even the garage I took it to recently said it was a bit loose. Are the drop links easy to do? I imagine I need to the the ARB off, so I may as well do the bushes for that at the same time. Even worth doing the roll bar (the look pricey online) Are the bolts just single nut, or do I need to hold the middle while undoing the nut? Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 26, 2013 Bolts are single nyloc so the droplinks are very easy to replace. Bushes are also worth doing, but if you do them after the droplinks theres no need to drop the whole ARB. Aftermarket ARBs are very expensive, and I doubt (although not from experience) you'd notice any difference in most of the driving your likely to do. Do them first, but look at your top mounts too whilst its on the ground. Have a look at the sticky http://the-corrado.net/showthread.php?t=41755 as clunking over speedbumps can be a sign they're worn. Quote Share this post Link to post Share on other sites
