Mawrick
Can I use this fuel pump on the Corrado VR6? (Pierburg)
Anyone know if I can take the fuel pump that sits in my VR6 estate Passat (1991 model) - model: Pierburg: 333 919 051 e
and put it in my 1995 VR6 (with a VDO pump).
Was the Pierburg models ever used in the Corrado VR6 ?
i think the VRs only came with VDO pumps, which replaced the Piersburg pumps. Maybe someone could confirm that. If you can use it i have a piersburg gauge sender and float for sale which i bought accidentally. Its new, never been used just need shot of it and it was too expensive to just throw away.
Ahh - so the sender etc will be different? (I presume the sender from the Passat won't be the same or?)
No only a piersburg sender will fit a piersburg pump and the same for VDO pump and sender. Not sure if the sender from the passat will work. Though i would say that if the pump from the passat can be used in the corrado then the sender will be the same.
Early vr's had piers burg pumps , they changed around 93 I think , to vdo , so if you have a shot old pump like mine and you buy the new Bosch one , the sender will not fit .
Then I presume the Piersburg from my 91 Passat VR6 would fit the Corrado ?
Also any idea if these pumps where "better" ? (ie not having that "leaking back" issue they resolved with the non return valve ), as I think that's the problem with mine........
I guess I can't do any damage if trying to fit it either - the electrical connections seem to be the same atleast :)
I don't know if they were better , but I would have thought it would fit , yes . I am awaiting a second hand pump ATM , so I can hopefully resolve my fuel issues .
Just saw a used golf-vento gti/VR6 VDO pump for sale localy for roughly £70 - any idea if this one is the same?:
Pic of it:
That looks like the new Bosch pump . You should be ok as it has the sender attached .
It should be the VDO pump - but as the add says it got a new sender and "housing"....so maybe that's the reason ?.
The casing is how the new ones come , the new one I bought is exactly the same . The top of my original is white not black , so maybe they have replaced that as well , give Them a shout and check for fitting but it should be fine .as said it would have a new sender , as the original one won't fit the new version .
Yea - according to him it's all VDO actually - but anyway, is £70 an ok price ? (I guess up here is a bit more expensive then the UK (normally) but anyhow :) )....lol
The price seems fine to be honest , yeah vdo is the new version . These pumps are ranging from £122.00 to £488.00 in the uk , so you have to shop around .
Tried to have a look at the Passat pump today - but can anyone tell be if the pump on the Corrado also sits down in the tank ? - and how do you get it out from there? - how is it fixes in position there?
Yeah sits in tank and is down by a twist lock system twist left to undo and right to replace
Do I need to push it down to twist or ? (and would it sit hard?)
Just twist, to get a good grip I got a latex glove on as my tank was half full at the time so less chance of slipping off
As Jon says , locate the whole , turn clockwise and you will lock it in place . The above info I gave to you was courtesy of Jon , who kindly relayed it to me . Great forum , without the info we all put in where would we be ? So credit to Jon .Oh and be careful with the sender arm when fitting .
Edited by robrado974
No worries mate, its good to share knowledge as me having just changed the pump its fresh in my mind. And here for other people to find when they do a search. Hopefully you get yours sorted soon mate
Being sorted while I'm on holiday , my friendly mechanic is doing it for me . I didn't want fuel evaporating away for a week while I'm away . I've had to plug the hole while I'm waiting for pump to arrive . Easy fix with the right pump though .
Ha yeah I had to plug mine up when I got the wrong pump...was expecting to wake up one morning with the car in flames
