VAG-hag
VR6 Breaking - Some stuff still going cheap
do you have one of these - think it's called a isv dampener??
I think so. Ill get up to the garage this week and confirm for you
Hey man ,
I'm after some little parts for my corrado can you help ?
If you open your fuel flap , there's a rubber seal thing that goes round the bodywork ? I need that as mines go missing since being painted . Also , in the same place there's a piece of trim plastic I think , that goes into a square when the fuel fla is shut ? It holds it up a bit to align with the body work .
Hope that makes sense !
lower lip as in splitter? not available if so.
I think I have the pulley though so will check tomorrow for you. thanks
