Danhowyn
G60 corrado recirculation
My corrado has not been giving me any low end boost and kicking in around 3000rpm
I do not have a recirculation pipe from charger to the by pass/blow of valve
Also my valve cover breather goes straight to atmosphere!
Does anybody no where I could get the pipes from or who has any for sale?
Thanks dan
I have a pipe in my garage
Think I have the hoses from the throttle body vent and rocker cover breather.
Not sure on postage due to size and shape
Ohh okay thanks alot mate!
How much do you want for it? And where are you from? I could collect?
Thanks dan
Does £20 seems fair to me.
Ill get some pics this weekend if I can.
I'm in Poole, Dorset.
Collection is fine if its not too far.
Replacing the boost return pipe is a good Idea if it has not been deleated properly, but it sounds like you have got a boost leak and or the charger needs a rebuild. I would have a look around the engine bay at all the hoses between the charger and the throtle body. Also check the vacume hoses while your there, with the engine off and with it running. You could also use the MFA to get an idea of how much boost you are getting. I think there is a how to on here somewhere, if not go to the matey matey G60 guide. Good luck.
That's quite a while away from me pal! About 140 miles.
And yeah some pictures would be good please? Would you beable to do postage?
Thanks dan
