delfinis38 1 Posted August 15, 2013 (edited) Was their a difference in the front calipers fitted on a VR6 through the years ???? I have lucas with 54mm pistons with vented discs 22mm thick europarts are listing 2 different types up to year 1993 vented 22mm and 20mm solid disc... my cars a 1995 model with vented discs..... I assume if I buy a caliper from a 1993 car it will fit a 1995 as long as its for a vented 22mm disc. europarts didn't know when I asked. Edited August 15, 2013 by delfinis38 Quote Share this post Link to post Share on other sites
mr.ots 10 Posted August 15, 2013 Looking on Vagcat the 92 VR through to the 95 VR all show the same part number for the front calipers. Quote Share this post Link to post Share on other sites
mic_VR 3 Posted August 15, 2013 Do you want some standard calipers? I've got an old set, they'll need a refurb but I'm sure I can part with them for an appropriate price. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 15, 2013 Do you want some standard calipers? I've got an old set, they'll need a refurb but I'm sure I can part with them for an appropriate price. Thanks for the offer. However I have a set which I sheared the drivers side bleed nipple off today. I,ve manager to drill it out but not tapped it yet. I,m assuming when I put the tap in, the thread will be rather slack. I,ve looked into refurbing these or another set and finally decided to either invest in a new set from veedub or a remanufactured set from euro or vw spares. Quote Share this post Link to post Share on other sites
mic_VR 3 Posted August 15, 2013 Well that's fair enough. If you change your mind just let me know. Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 16, 2013 Well that's fair enough. If you change your mind just let me know. Cheers, going to make a few phone calls this morn before I finally decide. Quote Share this post Link to post Share on other sites
Dox 23 Posted August 16, 2013 Be aware its not a standard thread pitch when you come to re tap the caliper, you need a 10 X 1mm tap Quote Share this post Link to post Share on other sites
delfinis38 1 Posted August 16, 2013 Be aware its not a standard thread pitch when you come to re tap the caliper, you need a 10 X 1mm tap thanks for the heads up.... I realised when I found it wasn't a standard pitch and I had no tap for it :) decided not to buy a tap and seal kit in the end and have order a set of refurbed pagid calipers from euro parts. which work out to be about £50 quid each after discount and the return of my old units. VW only have O/S to order now N/S is now obsolete. Quote Share this post Link to post Share on other sites
