quicky1980
Panels needed
need the piece missing in this picture to weld up the hole (front passenger side inner panel by battery. If no one can help can someone tell me if this is available from VW or if its the same piece as a golf mk3?
Also looking for the leading edge of the top of the windscreen. Can any one help?
Thanks
I may be able to help with shell cuts next week if you can't get sorted before - The screen top is rotted on the one I'm cutting though
cool, it does look the same as the corrado. Can anyone confirm? Thanks Dox, but if the new panel works out then Ill go this route.
Would still need the windscreen edge from someone though.
