Jon_vr6
Oil Sump bolt question
Right just a few quick questions
Oil sump, there are 2 gaskets listed for the vr6 i presume with mine being a storm i need the later?
021 103 609B ?
Now the question why are there 2 different thread depths for the sump bolts and does it make a difference which is fitted?
N 900 084 01 - M6 X 14
N 904 234 02 - M6 X 17
Cheers
Jon
Longer bolts and later gasket for you mate. The early gasket is a fibre one and thinner, the later gasket is rubber and thicker so requires the longer bolts.
