robrado974 1 Posted October 30, 2013 Hi all , Would I still get a spark if the ignition switch is gone kaput ? Thanks Rob . Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted October 30, 2013 No it wouldnt. Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 30, 2013 Thankyou sir Rob Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 31, 2013 Sometimes... they can fail in an odd way and break up inside but generally no... Quote Share this post Link to post Share on other sites
easypops 8 Posted October 31, 2013 When mine failed it would start sometimes, and sometimes not. Not sure about spark though. But for as long as I can remember, my starter motor was very slow turning. I was very close to getting another until I did the hotwire test, bypassing the ignition switch. Suddenly my starter motor was better than ever . New ignition switch and been great since Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 31, 2013 Thanks for replys , I will change it , it's not a lot for a new one , if it starts brilliant , if not , it's back to the drawing board . Rob Quote Share this post Link to post Share on other sites
easypops 8 Posted October 31, 2013 (edited) Have you tried this, cheaper than buying a switch...... But remember to keep your key in the ignition as it'll just cut out(transponder) Hopefully you'll get to the bottom of it soon http://the-corrado.net/showthread.php?t=3167&highlight=ignition+switch+bypass Edited October 31, 2013 by easypops Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 31, 2013 Thanks for this easypops much appreciated . Rob Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted October 31, 2013 (edited) For the price of a new switch its worth changing. THough you'll have fun getting the screw out holding the ignition switch in.. prepare for swearing and a bad back. Edited October 31, 2013 by Critical_Mass Quote Share this post Link to post Share on other sites
aide 0 Posted October 31, 2013 meet the ignition switch screw = the smallest, most inaccessible, body contorting, back hurting, stuff falling in your eye whilst undoing screw EVER! i filed nail grooves all way round edge to make it easier to turn most way back in. [ATTACH=CONFIG]76201[/ATTACH] Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 1, 2013 I will be looking forward to the dreaded screw replacement , seen it come up a few times in other threads . Thanks again Rob Quote Share this post Link to post Share on other sites
easypops 8 Posted November 1, 2013 Once you get it out, you'll not want to put it back in......a couple of well placed tie straps are just as good :) Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 1, 2013 Ok , never done one before , so will have a look at the search , before hand Rob Quote Share this post Link to post Share on other sites
kerrly 0 Posted November 2, 2013 I've done a few of them now and often it's easier to undo the UJ and take the column out giving you fine access to the ******* screw. Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted November 2, 2013 They're usually not done up tight from the factory meaning you can use a flat screwdriver and hammer to tap it around from the side. Alternatively, it's quicker to use the hammer and screwdriver to break it off. Look at your new switch and you'll see the little bit of plastic you're trying to break. Absolutely no need to take the seat out etc. Take off the cowling and go from the top. As above, just use a cable tie with the new switch ;) Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 4, 2013 easypops said: Once you get it out, you'll not want to put it back in......a couple of well placed tie straps are just as good :) Definately this, just make sure they're tight enough so the ig switch doesnt move. Quote Share this post Link to post Share on other sites
