Goldie 2 Posted October 30, 2013 How interchangeable are ABS lights? There is nothing wrong with my ABS but id like to have the option of running a different light (US Spec). Does anyone know if this would work? Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 31, 2013 Hello mate, I think they are all or most of them are 8 pin, with only 7 of the pins used, this is the German spec one from Classic Parts Centre, http://www.vw-classicparts.de/shop/ From German to English = Indicator light for trailer operation and anti-lock braking system 8-pin fitting. I think the American spec one is the same with 8 pins, so it should fit as well. http://www.ebay.com/itm/Corrado-brake-ABS-indicater-light-535919235A-/121152366315?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c353e66eb&vxp=mtr I don't think you can purchase the early UK spec ABS warning light any more, but I think you can the later UK type, it's around the £85.00 mark from VW dealer. Hope this helps. Si Quote Share this post Link to post Share on other sites
Goldie 2 Posted October 31, 2013 I think so, its for a late VR6. Does this mean an early G60 (US) is the same pin arrangement? Im sorry to be a nuisance, id just like to understand the differences. Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 31, 2013 I believe they are about the same, most of the time it's just the differences with the design of the front illumination, of the ABS symbol. But normally there's a circuit diagram on the top inner white plastic casing, which should show you live, earth, signal trigger wire and so on. If you carefully pull your ABS warning light out from the dash, you'll see or should see this diagram on the ABS sensor switch, plus you should see it'll have 8 pins and only 7 are used, I think. Some early ones I've seen have had 5 to 6 pins used out of the full 8, but these are rare. This I think is the later UK / Euro type ABS warning switch http://www.ebay.co.uk/itm/VW-CORRADO-ABS-LIGHT-G60-VR6-16V-8V-535-919-235-AA-535919235AA-/320908152866?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4ab79dd022 ABS Dash Data Sheet for early USA spec vehicle http://www.jimellisvwparts.com/showAssembly.aspx?ukey_assembly=737724 Hope this helps. Si Quote Share this post Link to post Share on other sites
Goldie 2 Posted October 31, 2013 I have pulled it out and it is the one in your last ebay link. Only 5 pins are used though.. Thank you for doing your homework.. Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 31, 2013 No worries. Si Quote Share this post Link to post Share on other sites
