Roger Chatfield
VR6 crank seal, how difficult to replace??
Evening chaps,
Out of interest how difficult is it to replace the crank seal??
I realise the gearbox needs to come off but is it then just a case of digging the old seal out and replace or is there more to it?
Rog.
Really easy, when you buy it from VW it comes with a plastic thing to help fit it, but i lost that the 2nd time and managed quite easily without.
Think i used two bits of wood to gently tap it in with a hammer
Indeed. Not too much needs to come off to remove the GB, so as long as you can get the car up at a reasonable height to menouvre it out, you'll have no trouble Rog.
if yours is leaking it may have already contaminated the clutch. My brother's VR6 went in for a new seal and clutch last week after his failed.
