dickie 0 Posted November 29, 2013 Hi, my 2.0 16v is cranking over but not firing. Any common problems? Would it turn over if it was the ignition switch which I know can be a problem. Thanks for any advice you can give. Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 29, 2013 Do you have spark? The hall sender on the distributor can break down Quote Share this post Link to post Share on other sites
jamesoff 10 Posted November 29, 2013 Do you have spark? The hall sender on the distributor can break down Seconding this, happened to me earlier this year. Quote Share this post Link to post Share on other sites
dickie 0 Posted November 29, 2013 I'll about to go through all the spark, fuel etc in a minute. Sounds like it could be worth replacing anyway Quote Share this post Link to post Share on other sites
daveb142 10 Posted November 29, 2013 I have a spare distributor with leads etc still connected if needed? removed from my 9a Quote Share this post Link to post Share on other sites
dickie 0 Posted November 30, 2013 Thanks as it looks like the ht leads are falling apart but I've just ordered some as want to get it back running asap Quote Share this post Link to post Share on other sites
dickie 0 Posted November 30, 2013 I'm getting spark, put a new distributor cap, rotor arm and leads on as they were looking old but still turns over fine but no start :-( Quote Share this post Link to post Share on other sites
dickie 0 Posted November 30, 2013 Found it, fuel pump fuse looked good but went to remove it and it'd fell apart inside the fuse box! Quote Share this post Link to post Share on other sites
