Thomas Boyce 10 Posted December 9, 2013 anyone know if theres a way to tighten this or do i just hit it with a rubber malet as has been suggested to me, definately dont want to break it as parts are getting hard to find. The car does still change gear fine at the mo but its so loose the weight only just sits in the guide hole and you can hear it rattling over bumps any suggestions would be helpful thanks Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 9, 2013 is something missing? the weight should be firmly bolted in place on the raised part of the cable to lever fixing bolt. Quote Share this post Link to post Share on other sites
Thomas Boyce 10 Posted December 9, 2013 the weight is firmly in place its the bit under it that has lots of play, could be a washer has deteriated or something, cant find any diagrams of what its supposed to look like anywhere or whats supposed to be there but i dont think it was that loose when i got the car Quote Share this post Link to post Share on other sites
Thomas Boyce 10 Posted December 9, 2013 the actual bit it bolts onto that hold the selector arm thing, ill try and post a picture Quote Share this post Link to post Share on other sites
Thomas Boyce 10 Posted December 9, 2013 [ATTACH=CONFIG]76647[/ATTACH] its number 5 on this diagram i found in a video Quote Share this post Link to post Share on other sites
Thomas Boyce 10 Posted December 9, 2013 the lever fixing bolt itself is loose, looks like it should screw in but a video i watched online said it pushes in and to hit it with a rubber hammer, doesnt seem right Quote Share this post Link to post Share on other sites
steveo29 0 Posted December 9, 2013 number 5 the stud/bolt thing does screw in , theres nothing there that you fix with a hammer take a decent photo and post it up Quote Share this post Link to post Share on other sites
Thomas Boyce 10 Posted December 9, 2013 just took it all apart and it seems the washer bit that goes under the cable is not there at all, guessing it was plastic and deteriorated, gonna see if i can find a washer to fit it tomoro, glad i didnt take a hammer to it Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 9, 2013 Should be a very thick metal washer Quote Share this post Link to post Share on other sites
