aaron-g60 10 Posted December 11, 2013 Anyone got a spare knocking about I could purchase until after crimbo when I can get the stage 2 ???? Quote Share this post Link to post Share on other sites
vw rule 19 Posted December 11, 2013 Hello there, I've got an old secondhand clutch with came out of my own Corrado, this clutch has done about 85,000 miles. I've got the clutch pressure plate and the clutch assembly disc, but don't have the release bearing as the old one was too warn to keep as a spare. This old clutch of mine has come out of a 2.0 16v Corrado, but it should be the same as a G60 clutch. The clutch is 228mm in diameter and has 28 splines, plus it's the original as from new, the make is I think Sachs. There's a bit of a wear lip on the clutch assembly disc, and the pressure plate lining is warn close to the rivets, so you've got around 6000 to 8000 miles or may be a bit more. I'll just charge you £5.00 for the clutch for both the parts I have. Please see photo's attached below. [ATTACH=CONFIG]76654[/ATTACH] [ATTACH=CONFIG]76655[/ATTACH] [ATTACH=CONFIG]76656[/ATTACH] [ATTACH=CONFIG]76657[/ATTACH] [ATTACH=CONFIG]76658[/ATTACH] [ATTACH=CONFIG]76659[/ATTACH] [ATTACH=CONFIG]76660[/ATTACH] [ATTACH=CONFIG]76661[/ATTACH] [ATTACH=CONFIG]76662[/ATTACH] [ATTACH=CONFIG]76663[/ATTACH] If this looks ok and is what you're looking for, then I can send it on a 2 to 3 day carrier as it'll be cheaper, or I see you are from Swindon which is just the other side of Salisbury, so I could meet you half way or can drive to your place ? For the 2 to 3 day carrage I'll have to get a price on that, but it should be around the £10.00 to £12.00 mark due to the weight and size. Or for me to drive all the way to your place I'll just ask for £5.00 for a bit of petrol money. Hope this helps. Si Quote Share this post Link to post Share on other sites
aaron-g60 10 Posted December 13, 2013 Thanks for taking the time to reply, think I'm going to go for a new black diamond set up instead this week coming. Saves doing it twice that way. Thanks again Quote Share this post Link to post Share on other sites
vw rule 19 Posted December 14, 2013 Ok mate no worries, just thought I'd post it up just in case you wanted a clutch, to fit urgently on a temp basis. Hope it's a smooth job when you fit your new replacement clutch. Si :) Quote Share this post Link to post Share on other sites
