borders16v 0 Posted December 14, 2013 Hi.Well Ive broken the 2.093 16valver again. My battery was old and starting from cold was slowing but fine if it was warm so I disconnected it and fitted a new one in about 5 mins. The car turns over nice and strong but struggles to fire up.It stutters for a few seconds then dies and after 8-10 attempts with pumping the gas pedal it will start up. Its fine when warm. So I must have thrown something by changing the battery but what ? Am i meant to do a ecu reset when fitting a new battery maybe and if so what is it ? Thanks for any help that anyone can offer. Quote Share this post Link to post Share on other sites
vw rule 19 Posted December 15, 2013 Hello there, on some vehicles once the battery is disconnected you can some times lose the basic ECU settings, if the battery has been disconnected for 20 to 30 mins or more, but this normally relates to vehicles that have the full multi point fuel injection system, where the injectors are linked directly in to the ECU as well as most of the other engine sensors, on these such vehicles you'd have to use a diagnostic scanner to remove any fault codes from the ECU memory chip, and drive the car for 30 to 40 mins so the ECU can collect fresh data from all engine sensors, and log all basic related settings back in it's memory. On some of the new vehicles this can happen if the battery is disconnected for long periods. But on your Corrado 2.0 16v as it's got the old style fuel metering head like on the later MK1 Golfs and MK2 Golf GTI, it's basically mechanical injection as it has the fuel distributor, fuel governor and air flow sensor all in the one metering head unit, so this set up doesn't really lose it's basic ECU settings unlike the more advanced ECU system like on most modern cars including the VR6 but as you've said it only took 5 mins to replace the battery you should be ok, from what you've said it does sound like one of the circuits has had a power surge or something for a split second, which can happen when you replace a battery. You should always remove the black negative (EARTH) lead first, and it should always be the last lead to fit back to the battery terminal. The red live (POWER) lead is always the second one to remove from the battery, and should be the first one to fit back to battery terminal before the earth lead. If you don't fit and remove the battery terminal leads as above then you can course a small power surge, or in some cases it can course a short, it can still happen if you do use the correct procedure but it's very rare. . Plus you've said that you have to apply full throttle to start your Corrado up from stone cold, this again is a classic symptom of over fueling. Full throttle down to assist starting is a symptom of a lack of fuel / too much fuel / very weak spark / very low compression. But like I say in your case as your Corrado starts fine when it's warm / hot, and is difficult to start from cold it'll be too much fuel meaning the fuel to air ratio, will be out so the engine will stall when cold or idle very lumpy until it's up to temp. It does sound as though the Coolant temp switch has died or is on the weak side, this can affect the car starting from cold or even when the engine is warm, it really depends on how the coolant temp switch has burnt out. They are normally white or blue in colour and have a 2 pin plug on the Corrado 2.0 16v The other thing it could be is the Lambda sensor, this detects any un-burnt fuel deposits with in exhaust waste fumes, but normally you'll have erratic idling and can have highish fuel economy complete with engine being under powered slightly, plus you might hear the odd popping sound from the exhaust tail pipe due to the extra fuel being used. These normally on the 2.0 16v have a black 4 pin plug with a separate earth wire. Most OEM Lambda's are Bosch ones, cost is around £58.00 to £78.00 off Ebay Some times the cold start injector can stick open which floods the cylinders with fuel, again coursing bad cold starting. This is normally linked into the coolant temp switch circuit, so once the engine warms up slightly the coolant temp switch, should then tell the ECU to turn off the cold start program. Secondhand these are around £25.00 to £38.00 off Ebay, and new from VW Main Dealer they could be close to £100.00 if not more, that's if they still stock them, if they don't then try VW Heritage. This is the part number for the 1.8 16v cold start valve ( 026 906 171A ) it might even be the same for the 2.0 16v. When testing the cold start valve / injector you can remove the 2 pin connector plug and see if it effects it's running on start up, or you can remove the cold start valve from out of the inlet manifold and see if it is switching off correctly, but if you do remove the cold start valve it could rip / damage the gasket. You can do a similar thing as above and remove the connector plug off the Lambda sensor or coolant temp switch, again just to see if it makes a difference or not to the engines cold start up. This is what some of the Forum members have done just to rule out each possible error from some of the sensors in question, that relate to this cold start up problem. When starting your Corrado 2.0 16v from cold it'll idle at around 1150 RPM for 3 to 5 mins in really cold winter weather, and around 1 to 2 mins in mild weather and even less in the summer weather. Once the cold start program has switched off, your engine should then idle at 850 RPM. I've got a spare coolant temp switch if you want it, it still works and has done around 75,000 miles. The part number is ( V026 906 161 ) this is a 2 pin and has a 10mm diameter thread with 1mm thread pitch complete with washer. I don't want any money for it you can have it F O C, if you want it and if that is the problem with your current one. Basically the same as this one on Ebay. http://www.ebay.co.uk/itm/261233673855?ru=http%3A%2F%2Fwww.ebay.co.uk%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D261233673855%26_rdc%3D1 Hope this helps. Si 1 Quote Share this post Link to post Share on other sites
borders16v 0 Posted December 15, 2013 (edited) Hello Si Thankyou very much for taking the time to respond to my query in a such in depth and helpful manner.You really are a credit to this forum for taking the time to help out a stranger. Ive had to leave the car and will try to fix it between the turkey sandwiches over Christmas. I replaced the battery removing the cables in the right order but they do look rather old and may have caused a short with me wiggling them about maybe? The sensors are all original never been replaced so may well have failed,been fried by me.I will remove the battery again and refit,leave on ignition for 5 mins then try starting it and if it fires take it for a good run.This was recommended on the vwvortex site. I must say i dont think it will work so will work my way through your recommendations starting with the temp sensor. My problem is im useless with auto electrics so no doubt fixing this fault will be "fun" Im going to reread your advice right now and hopefully this will sort me out. Thanks again for helping me out, much appreciated and have a good week. Cheers Jon Edited December 15, 2013 by borders16v Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 15, 2013 I don't think the 2.0 16v ecu has any learning capability, it's very basic and so is its fault recording. Ideally you want vcds/vag com on a laptop an a 2+2 adapter cable to read any faults with the car running. However it is fairly easy to check the temperature sensors with a multimeter over their temp range to make sure they are within limits, just a temp/resistance graph. Lambda will not affect fuelling on this car until it is fully up to temp. Quote Share this post Link to post Share on other sites
borders16v 0 Posted December 15, 2013 So more info pointing towards a fried temp sensor? Thanks DW. Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 15, 2013 Check all the easy stuff, things like the earth strap from the head to the bulkhead, wiring close to the connector plugs for damage and corrosion, starting ok when warm may suggest high resistance in wiring somewhere which is higher when cold. Quote Share this post Link to post Share on other sites
borders16v 0 Posted December 15, 2013 Maybe i damaged a wire when refitting the battery ? Batery tray looked ok but some of the wiring looked every bit of its 20 years of age,scary! Thanks again for your help. Quote Share this post Link to post Share on other sites
vw rule 19 Posted January 6, 2014 Hello Jon, please find attached photo's as mentioned. [ATTACH=CONFIG]76919[/ATTACH] [ATTACH=CONFIG]76920[/ATTACH] [ATTACH=CONFIG]76921[/ATTACH] [ATTACH=CONFIG]76922[/ATTACH] Si Quote Share this post Link to post Share on other sites
