P3rks 11 Posted January 5, 2014 Hey you guuyyyysss! Regarding the top timing cover; I believe they don't have a gasket and you have to use sealant, can anyone recommend the best one to use? Thanks! Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 5, 2014 The VW stuff is white, and is uber expensive apparently. There is a loctite alternative available from Halfords though from what I remember. 381 or something like that anyway...... Quote Share this post Link to post Share on other sites
VW_OwneR_85 1 Posted January 6, 2014 http://www.ebay.co.uk/itm/DIRKO-ELRING-VW-AUDI-SEAT-SKODA-ENGINE-SUMP-SILICONE-GASKET-SEALANT-D176404A2-/171015704173?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27d1548e6d Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 6, 2014 VW use the white stuff on the sump and a Loctite black silicon for the side covers. Can't remember the number though, I'll try and dig it out. Quote Share this post Link to post Share on other sites
P3rks 11 Posted January 6, 2014 Thanks lads. Kevin, try and dig it out please. Also, what's the best application method for it? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 6, 2014 Ah, found it. Loctite 5900 flange sealant. Alternatively, as mentioned, Halfords sell Loctite 5910 which will work just as well. The dealer supplied stuff comes in a syringe, so easy to apply. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted January 6, 2014 I just use a hylomar blue non setting gasket type thing, can get it from most petrol stations. Never had an issue and done mine 3 times now. Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 6, 2014 I've used this on mk4 sump and have also used the white VW stuff, the Dirko-Elring sealant is pretty much as good as the VW stuff and it worked well on my Corrado gearbox selector tower bottom bearing cap too. Not sure why VW would spec a different sealant for side covers though??? http://www.ebay.co.uk/itm/DIRKO-ELRING-VW-AUDI-SEAT-SKODA-ENGINE-SUMP-SILICONE-GASKET-SEALANT-D176404A2-/171015704173?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item27d1548e6d Quote Share this post Link to post Share on other sites
P3rks 11 Posted January 6, 2014 Nice one guys! Loads of options then. As for the application though? Use sparingly? Loads? Wait for it to tack or tighten it wet? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 6, 2014 (edited) I can see why VW specify a heavier duty sealant for the side covers on the VR6. The join between the upper and lower covers is prone to leaking and you need a good dollop of heavy duty stuff, applied in the right place, to stop it. The white sump stuff is a latex blend. The excess sealant doesn't fall off and clog up oil pumps. Don't apply loads! A nice even thin layer. Edited January 6, 2014 by Kevin Bacon Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted January 6, 2014 i literally squirt it onto my finger and smear the thinnest layer i can over the cover. Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 6, 2014 Nice one guys! Loads of options then. As for the application though? Use sparingly? Loads? Wait for it to tack or tighten it wet? I think the dirko stuff said wet-on-wet, so I put a thin bead on both sump and block and bolted straight up, left overnight before running but I don't think it needs that long. Use sparingly though, as on most flat surfaces you'll just squeeze loads out of the sides and you don't want bits of sealant possibly coming off inside the engine. Quote Share this post Link to post Share on other sites
VW_OwneR_85 1 Posted January 6, 2014 just make sure both surfaces are clean and free from oil, brake cleaner's perfect for this, I recently had to do my timing chain cover as it was leaking , iv only done the upper and when I split it apart there didn't appear to be any sealant, really gutted that I didn't remove both covers when I fitted that engine {24v} it didn't cross my mind at the time :( ah well when I eventually need to replace the clutch i'll re seal both Quote Share this post Link to post Share on other sites
P3rks 11 Posted January 7, 2014 Thanks so much for the tips boys. That's one more thing off the list of things to do. :) Quote Share this post Link to post Share on other sites
