ChrisL
Clarke Engine Stand
With my engine coming out on Sunday, Im borrowing a Clarke 500 Engine stand that I was going to mount it on while I clean/paint, change the sump.
Has anybody mounted a VR6 on such a stand as I'm after ideas on where it mounts. The gearbox will be removed first.
Cheers
I mounted mine using the rear engine mount, Took the bracket off and used 3 of the holes in the back of block.
Although it took a bit of working out getting the right bolts and using spacers etc
