ChrisL
Snapped suspension Bolt - any ideas?
Stripping the front subframe and I've managed to snap the horizontal bolt that holds the bottom arm. Trouble is its snapped so the bottom arm wont come off.
Has anyone done this before and hows best to remove it please?
Will have to do it tomorrow.
Its the one at the front of the subframe that holds the front part of the bottom are.
Nasty !
I did that & it took ages to get it out.I used an air powered saw & a bare hacksaw blade to cut through the bolt on the far side of the bush,with the wishbone off I drilled a hole in the remainder of the bolt & then mig'd a 6mm bolt into it ,unscrewed & luckily it came out.
At least you have the sub frame out which will make it easier.good luck
Thanks Daren,
I did think I would have to cut it through the back part. Reckon the other one is going to do the same too.
Will take it to work I think.
Was it your passenger side that snapped ?
It's usually that side & the drivers side is often ok because it's protected by the sump & the heat from it prevents so much corrosion
Yep thinking about it, it was the passenger side. The drivers side seems just as tight so that is likely to go too.
Had an impact gun on it and didnt shift it.
yea mine was an absolute pig to do due to it being on the car and drilling from under the car wasnt fun but the new thread tapped good , a mm or 2 off center but worked well, with it being off the car you got it way easy ;)
Yep one of mine did this too Chris, junior hacksaw abd then drilled out and re-tapped. Make sure you check the repair with the wishbone inplace before you get everything powder coated though as no point paying out for that if the thread you just tapped in wont hold a bolt to the correct torque.
And if this is the bush we talked of earlier then yes they are available ;)
Thanks Kip, I will definately check before powder coating.
Dont suppose the bush part number is 357-407-182 is it?
