p0l1wrath
Has my diff gone?
So if I jack my car up in the air, start it and put it in gear the n/s wheel spins fine but the o/s wheel stutters, when I hold the n/s wheel the o/s wheel spins fine, the reason for all this is when it gets warm it gets real knocky
Anyone know this?
Cheers
Actually that's a silly question, but when it's in neutral with the engine not running, if I spin either wheel either way, it doesn't move the other wheel at all
Ok, that happens, but the diff on my spare engine does that in neutral
Yes it might do that as you don't have the extra drag created by the driveshafts, brakes and wheels.
Even when in neutral you still get a thing called parasitic drag, it's worse when cold, it's this drag that causes the wheels to rotate when you run the engine when jacked up.
If you want to prove the diff on your spare box put it in natural hold the input shaft and one driveshaft flange and then rotate the other driveshaft flange, it should rotate, then put it in gear, it shouldn't rotate.. (I assume you don't have a LSD)
Rog.
I have the standard diff, and your theory works on both boxes, another quick question is, I have 5 degree play on the diff in my car, but absolutely none on my spare, this is when they are turn at the cups and both cold
Thanks
Nothing to worry about, it's normal to have a bit of play, it's just the back lash of all the gears meshing.
If your diff was broken you'd know about it, basically you wouldn't get any drive.
Rog.
Rog.
4.5 maintainer by any chance Rog? :lol:
