sankysvr6 0 Posted March 29, 2014 Need help in knowing which the way the anti roll bar links are meant to go. Forgot to make a note in which way the old ones were. They are slightly offsets from the stud part. This is for a G60, so different to the VR6 A picture would be fantastic Quote Share this post Link to post Share on other sites
dragon green 5 Posted March 30, 2014 Does this help Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted March 30, 2014 Yes that's fantastic just what I needed, been looking all day on the net for a picture. Thanks a lot for your help Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 1, 2014 Do I need to have the car on the ground to fit the new drop links? As its currently on axle stands and I am having great difficulty trying to get the nut on the link where it goes through the arm. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 1, 2014 You want both front wheels off the ground and may need to use another jack under the wishbone to lift it up. Quote Share this post Link to post Share on other sites
sankysvr6 0 Posted April 1, 2014 Cheers Jim, managed to get the bolts on by pushing the bar down a bit with a lever. I've read somewhere that I should torque them up once its on the ground and after you bounce the suspension a few times. Quote Share this post Link to post Share on other sites
