Dave W
Steering wheel wobble
Getting grief from wobbly steering wheel at about 50-60mph. Car has had original wheels refurbed and new rubber. All balanced ok. New bottom arms and top mounts. Everything tight with no play or knocks. Getting really annoying now.Dont know what to look at next. Two of wheels were pretty buckled and are on back. Can you bend a front hub ???.
Usually wheel wobble points to wheel balancing though. I had problems last year and after various trips to different outfits it was finally sorted. I was told not all places get the wheel balancing machine calabrated which causes problems
I'd go to another tyre fitting shop and have all the wheels checked for balance, before thinking about bent stuff and replacing parts that are ok.
Looking through previous posts the car has been off road for 8 years, was it with these tyres resting on the ground?
All new toyos. Had full alignment done after all work done. Wheels have been balanced twice now. Would locking wheel bolts upset it ?. Might pinch front wheels of wifes Up to prove wheels ok.
Swapped fronts from Up. Wobble all but away. Small bit at 65 but far better. Will try balancing again somewhere else, could be old original wheels just past it. Hey ho.
You might want to ask them to look at the wheels on the balancer without the tyres on - see how round / balanced they are first...
What wheels are they by the way? Just wondering if you're missing spiggot rings if aftermarket alloys?
If original wheels then some are now peanuts from Classic Parts so maybe worth buying a new pair / set
On original 1.8 16v alloys. Had them blasted and powder coated but should have checked to see how round they were first !!. Of the 5 , 3 of them pretty badly buckled/dented. Usable but will look out for new uns. Wanted to keep it original.
