Strugs 10 Posted May 28, 2014 Wouldn't know the correct names for these parts, so thought I'd post pics instead!! Trim at top of door (driver's side, if they are 'handed'): [ATTACH=CONFIG]78718[/ATTACH] Handle to tip the seat forward (driver's side).. or should I just glue it back on?? [ATTACH=CONFIG]78719[/ATTACH] And this trim for the passenger seat: [ATTACH=CONFIG]78720[/ATTACH] Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 29, 2014 May have the tilt handle and seat trim piece in the shed, I'll have a look after work tomorrow and let you know mate. Quote Share this post Link to post Share on other sites
Strugs 10 Posted May 29, 2014 May have the tilt handle and seat trim piece in the shed, I'll have a look after work tomorrow and let you know mate. Cheers! :thumbleft: Quote Share this post Link to post Share on other sites
clumpy1 11 Posted May 29, 2014 If Sean hasn't got it I may have it Quote Share this post Link to post Share on other sites
Strugs 10 Posted May 29, 2014 If Sean hasn't got it I may have it Magic.. :) Loving this forum.. :clap: Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted May 30, 2014 I have the internal door strip. Where are you? Quote Share this post Link to post Share on other sites
Micky fletch 10 Posted May 30, 2014 I have the internal door strip. Where are you? Hi vag nice to see you again at bruntinthorpe . If he don't have it and it's a drivers side trim I'll have it . Thanks buddy Quote Share this post Link to post Share on other sites
Guest sam1990rhodes Posted May 30, 2014 my other half has managed to yank the chair handle-ma-bob off just last night!, it seems to have come off in once piece, you guys reckon it just a case of gluing it back on? Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted May 30, 2014 If it's the handle for tilting the seat then there should be a metal clip on the lever that it attaches to. If that's not there then you could probably just bond the handle back on. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 30, 2014 Just get a new one from the dealer for the cost of it. i.e. peanuts. If they're obsolete, I think MK4 R32 seat grabs have the same fitting. Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 30, 2014 Alright mate, I have the lower trim piece but can't find the handle I'm afraid. What I have is in pretty good order, although the centre tab has one tooth missing (it's on the back, you'll know what I mean if you have your old one off). Yours for £4 posted if you want it though. :thumbleft: Quote Share this post Link to post Share on other sites
Strugs 10 Posted May 30, 2014 I have the internal door strip. Where are you? Cool! Farnham in Surrey.. You? How much posted (is it postable??)? Quote Share this post Link to post Share on other sites
Strugs 10 Posted May 30, 2014 Alright mate, I have the lower trim piece but can't find the handle I'm afraid. What I have is in pretty good order, although the centre tab has one tooth missing (it's on the back, you'll know what I mean if you have your old one off). Yours for £4 posted if you want it though. :thumbleft: Cool! For the passenger side, yes? The car came without one so I've not seen the back, but I'm assuming it should still attach to the seat ok, and you can't see the broken bit when it is fitted? Quote Share this post Link to post Share on other sites
Strugs 10 Posted May 30, 2014 Just get a new one from the dealer for the cost of it. i.e. peanuts. If they're obsolete, I think MK4 R32 seat grabs have the same fitting. Good info! Might try gluing it back on initially and see how well (i.e. if!) it stays attached! Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 30, 2014 Cool! For the passenger side, yes? The car came without one so I've not seen the back, but I'm assuming it should still attach to the seat ok, and you can't see the broken bit when it is fitted? I have both sides so no worries. Is it passenger door side, or handbrake tunnel side you need? Teeth are not visible when fitted, and it secures perfectly well so not a problem what so ever mate. :thumbleft: Quote Share this post Link to post Share on other sites
Strugs 10 Posted May 30, 2014 I have both sides so no worries. Is it passenger door side, or handbrake tunnel side you need? Teeth are not visible when fitted, and it secures perfectly well so not a problem what so ever mate. :thumbleft: Passenger door side.. nice one! PM me with payment details and I'll reply with my address.. :) Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted May 30, 2014 Cool! Farnham in Surrey.. You? How much posted (is it postable??)? im in s yorks so not too local. But it will be corierable, the part is yours for 10 ill get back to you with p&p cost. Thanks. Quote Share this post Link to post Share on other sites
Strugs 10 Posted May 30, 2014 im in s yorks so not too local. But it will be corierable, the part is yours for 10 ill get back to you with p&p cost. Thanks. Ta! :) Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted May 31, 2014 if micky fletch needs one of them trims that vaghag has I will have one available Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted May 31, 2014 if micky fletch needs one of them trims that vaghag has I will have one available That be grand mate. If you pm him to arrange as its drivers he needs n I only have 1 Quote Share this post Link to post Share on other sites
