imyhamid 0 Posted August 11, 2014 Hi all, just wondered if I could have a little advice. I have a Corrado VR6 running standard speedline wheels on coilovers. The question I have is I am looking at spacers for the rear just to bring the wheels out slightly. The question is does anyone have any suggestions which adaptors to buy good quality and where from. If anyone is running them what size do you suggest. Cheers for any help in advance. Quote Share this post Link to post Share on other sites
leon263 0 Posted August 11, 2014 H+R are probably the best spacers that you can buy, just be sure that you buy a set of hub-centric ones which will securely centre the wheel on the hub. The narrower ones tend to be 'bolt through', where longer length wheel bolts are used. Wider one tend to be 'bolt on', where the spacer is bolted to the hub and the wheel is then bolted to the spacer. Again be sure they are hub-centric. If you are just looking for subtle spacing, then check out the set at the link below ........ brand new, 8mm per side with extended bolts and at an extremely good price. Failing that, e-bay is your friend. http://www.edition38.com/forums/index.php?showtopic=529096 Quote Share this post Link to post Share on other sites
mr lobitos 0 Posted August 11, 2014 what mm are you after ? got a pair of fk 25mm hubcentric @ £60.00 inc postage or 10mm tpi with extended bolts @ £ 30.00 inc postage Quote Share this post Link to post Share on other sites
imyhamid 0 Posted August 13, 2014 Thanks for the advice and pointing me in the right direction. I'm not sure what size I am looking for at the moment, I will get the measuring tape out tonight and get a rough idea. If you still have the 10mm ones available I will drop you a message. Cheers for the help. Imran Quote Share this post Link to post Share on other sites
VR-OOM 0 Posted August 2, 2016 Does anyone have any recommendations where to best place is to get hub centric spacers from? Cheers Quote Share this post Link to post Share on other sites
Ray1965 10 Posted September 10, 2016 Does anyone have any recommendations where to best place is to get hub centric spacers from? Cheers See Leon's post top of this page. Quote Share this post Link to post Share on other sites
Ray1965 10 Posted September 10, 2016 Advise needed: i have 5mm spacers fitted on the rears, i have VW Monties wheels on, the centre cap would not fit over the wheel bearing cover so this is why the spacers were fitted, the question is will it be ok to run this set up without the need to use longer wheel studs, bearing in mind it's only 5mm. Quote Share this post Link to post Share on other sites
subcool 0 Posted September 10, 2016 I got bolt on 20or25mm spacers from venom motor sport think they have a few different types! Sent from my HTC One M8s using Tapatalk Quote Share this post Link to post Share on other sites
subcool 0 Posted September 10, 2016 Sent from my HTC One M8s using Tapatalk Quote Share this post Link to post Share on other sites
culshaw 1 Posted October 10, 2016 Sorry to drag this up but I'm looking at some 15mm hubcentric spacers for the VR and the big warning (on the ebay ad) about spigot size has got me wondering. Will these fit ok on the fronts? http://www.ebay.co.uk/itm/121932948245?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT Quote Share this post Link to post Share on other sites
GUS 0 Posted October 10, 2016 Just spoken with Venom motorsport and they have the Stance+ 15mm hubcentric spacers for £32.99. They also supply the longer bolts. What's the spec of the standard bolts for the Speedlines. Quote Share this post Link to post Share on other sites
subcool 0 Posted October 10, 2016 Try venom motor sport! Sent from my HTC One M8s using Tapatalk Quote Share this post Link to post Share on other sites
