Temmsy
Help needed
Hi all some help is needed please, originally my car was struggling to start so I put this down to the starter motor but as of recent I have notice that without fail every morning she would start on the first turn of the key but the rest of the day is a nightmare, key turns and nothing then on maybe the 10th go a little burst then after that she will start, wondered if anyone has an ideas please
Hi. I had a similar intermittent problem. Despite cleaning all feed and earth terminals to and from the starter motor, the problem persisted. I sourced a vw reconditioned starter and solenoid from Deutscheparts and the problem was solved. Be warned the starter is a bit of a swine to get at!
robinw
Wiggle the key when its turned and not starting. Ignition switch is a common problem and a likely suspect so you'll know if it starts when wiggling. Other than that, as mentioned earths and feeds then starter motor.
