Thursdave
Carpet under felt / underlay options
Hi folks.
I've got the carpets out of my G60 at the moment drying off after a heater matrix leak - used the opportunity to give them a bloody good wash.
While I was removing the carpets, I noticed that the sound proofing / underlay (andele andele arriba arriba!) was sopping wet, so I've thrown it out.
Typically, I know find replacements aren't available.
What do people use to replace the underfelting? I can get the rubbery soundproofing, but the thick foam felt/matting stuff appears to be elusive to me.
Any tips?
Dave
Heritage have just started doing it
Sorry my bad, should have put those up
With forum discount here are the prices, tehy are plus VAT
Item Code : Item Name :
535-823-101 Bonnet sound proofing for Corrado models (not G60) 23.80952
535-823-101/G60 Bonnet sound proofing for Corrado G60 models 23.80952
535-863-919 Underfelt kit for under carpet, standard kit, Corrado 25.76365
535-863-919/D Underfelt kit for under carpet, deluxe, Corrado 45.2381
536-863-101 **SO** Carpet set, Corrado RHD in colour 142.85714
536-863-101/BLK Carpet set, Corrado RHD in black 142.85714
WC863101 2 Piece over mat set for Corrado RHD models 25.39683
http://the-corrado.net/showthread.php?t=85826
This explains everything
Brilliant! How's that for timing?
Fortunately my carpet itself is alright. Pressure washer, fabric cleaner, then carpet black and it's looking as good as new. :)
I used an eco flooring underlay. Works bloody well an car is ace on the motorways. An keeps sound in too. I'll find out exactly what it is. But 40 quid is about 3 cars worth lol
There's a really good quality dense rubber underlay available from Amazon for about 45 quid, similar stuff I bet, a great big roll about 20 sq m iirc, with soundproofing you need mass and that stuff is great and great value too
The only issue is the leak's that can appear without you even knowing. I used a Carpet underlay on mine (double thickness) and taped down with proper Heavy duty Duct tape. But mine is very rarely out in the rain with other's it may be different.
