robrado974 1 Posted November 23, 2014 Morning . Can anyone give me the size or a good pic of where the membrane should be cut to , how it's proper fit should be please . I need to get this done today as water is getting in . Kind regards Rob Quote Share this post Link to post Share on other sites
seanl82 23 Posted November 23, 2014 (edited) Just spent ages trawling through Clumpys thread, I knew I'd seen him post one up some time ago! :thumbleft: http://the-corrado.net/showthread.php?t=78738&p=1001036&viewfull=1#post1001036 Edited November 23, 2014 by seanl82 Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 23, 2014 Thanks Sean , for taking the time to find it , much appreciated . It looks like James has taken his lower than mine , the door card pegs go through the membrane by the looks of it . Quote Share this post Link to post Share on other sites
seanl82 23 Posted November 23, 2014 Thats original and how it left the factory mate. My original ones were like that too, but were in a much worse state at the top and around the speaker hole. Quote Share this post Link to post Share on other sites
clumpy1 11 Posted November 23, 2014 Just seen this chaps yeah like Sean said rob that is original my breaker was totally unmessed with. Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 23, 2014 Im off to find some membrane from somewhere in a bit . Im going to apply the butty tape , fix an oversize membrane on , check for leaks . If im happy i will fit the door card and trim afterwards .You can see droplets where the speaker wire protude too , so i will tape this area to death . Quote Share this post Link to post Share on other sites
clumpy1 11 Posted November 23, 2014 I've kept the one's from my breaker just incase I need them for the R got a funny feeling there missing. Good luck Rob :thumbleft: Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 23, 2014 Thanks James , I found a builders sheet in BnQ . It's the same thickness so that's good . Frustrating having wet carpet again ! Quote Share this post Link to post Share on other sites
fla 9 Posted November 23, 2014 (edited) Rob I used some heavy plastic sheeting (packaging for some items received) and stuck with butyl tape. I made separate pieces for each major hole in the door. I took some pics I think they're in my build thread - will check and let you know. Edit: here you go, post 77 http://the-corrado.net/showthread.php?t=42752&page=8&p=596733&highlight=membrane#post596733 Edited November 23, 2014 by fla Quote Share this post Link to post Share on other sites
robrado974 1 Posted November 23, 2014 Thanks Hasan . I've fitted the membrane . Used butty tape , tested it and no leaks . Quote Share this post Link to post Share on other sites
seanl82 23 Posted November 23, 2014 Well done mate, hope thats the end of it now! Quote Share this post Link to post Share on other sites
