julesz
Brakes??
Discovered last night that i have no brake lights, not sure how long for!! Found out last night by a mate in his 1.8T following me at full throttle!!! :shock: :shock: I have checked the fuse as neither lights are working. Fuse looks ok (Fuse 20 i belive). Think the bulbs are ok too as side lights work fine. What else could this be?? :(
Brake Pedal switch.........
Cheers Scott.. Where is this and what can i do about it?
situated on the back of the brake pedal - get down and have a look.... its quite high up... wires might have come detached or it could have broken....
Nice one - Ill have a look later on. Cheers!! ANyone got a part number or know roughly how much these are in case its broken? (and if its tricky to replace)
Well, had a closer look last night. passenger side bulb was black and covered in melted plastic from the surround of the light, where it seems to have melted a bigger hole for itself!!! :shock: :shock: :shock: Replaced this and it works fine. Drivers side bulb looks fine but still doesnt work. Will replace this afternoon. Any ideas why both bulbs should go and fuse be ok? :?
Just because they can.
Seriously tho', the fuse will only blow if it is subjected to a current drain greater than its rating. The bulb filaments burning out won't usually pull enough current for long enough to take the fuse with them.
Yup spot on *:)
hi guys this has just happened to me as well, im gonna check the same stuff tommorrow,
where can i find a guide to which fuse is for what??? anyone know?
Regards
Fuse info is also printed(?) on the underside of the fuse box parcel shelf
