Jamie
MKIV Golf Hub Adapter Plate
Back in the summer I was looking at spacers for the rear of my car and came across a site that made stub axle spacers instead of wheel spacers. I've also been looking for a way of getting a larger rear disc as well and just suddenly thought - instead of just a spacer, would it be possible to have a hub adapter made up so you could fit MKIV stub axles to a Corrado beam? Pretty sure if it was possible you'd have all done it but can't find a definitive "its impossible" answer...
Btw I know JMR and Eurospec do a kit but they're both out of my budget at the minute so I'm trying to do it on the cheap
No interest in this then? Shame cos I think I'm almost there with what's needed to run MKIV hubs
what's the advantage of running mk4 hubs?
For me - 280mm rear discs but you also get the advantage of more modern cartridge bearings
I thought PurpleTom used Polo GTi rear stubs with MK4 cartridge bearings, 256mm (Mk4 Gti rear) disks and calipers and carriers?
Sean - not 100% sure how I'm going to go about it yet but hopefully the track will stay the same, or in my case I may add 10mm to mine and bin my spacers.
That's a great find Emu nice one! Hoping to come in a fair bit cheaper than that though if I can.
Dox - that was the way I was heading originally but I've since read that MK4 hubs don't fit the Polo spindles. If Purple Tom has done it and they do, then that would be awesome!
Edited by Jamie
Purpletoms old car
http://the-corrado.net/showthread.php?t=89220
