Wayne2015
White VR6 in Windy Yorkshire! :)
Just tested my dash speakers using a 9v battery:
Nothing.
So they are dead?
Also
Unsure if I can find a replacement light switch loom.
If not,
Does anyone know what spec wire I need to replace the brown one?
Persevere with finding a loom, it looks burnt out up to the pin so will need replacing from there.
Oh
Ok, Sean ...
Rained overnight ...
The sunroof leaks this morning :( :( :(
From driver drain tube...
From driver rear drain tube...
Is it safe to disconnect the drain tubes (attached to sunroof),
Pull it off and poke a coat hanger in???
Will anything break by taking it off?
Or it s supposed to leak?
Lots of rain - but i wouldnt say its heavy ...:shrug:
My sunroof drains are fine :thumbleft:
So why the leak around the front AND rear drain outlets??? :bonk:
But are they clear all the way? Reconnect tubes and pour water into the gully see if water comes in from any where
Gone for this instead!
Steel - so better at pushing thru :lol:
Still £2 a metre = £6 :eek:
Cant
Sunroof broke :(
Darent open it again :eek:
How did you tell the tube are clear all the way down, blow down them?
I will have to, if that steel cable not go all the way! Grrrr
Happy guys?
About 2m pushed thru the front:
1.5metres for rear
But only passenget front cable pushed thru
The other 3 couldnt find its way out past the wheel arches :(
Thouh they all came out with a CLEAN cable
As Chuggs said,
Only way is to test with water ...and i cant. :(
Open it manually ?
I wish it was that easy, Rob! :eek:
One member did that and snap/broke his perfectly working spare sunroof
On eBay a seller did that and also snap/broke the sunroof he was selling
I did that (see link below)
And i do NOT want to be at a point sunroof can NOT be closed again :shocked!:
http://the-corrado.net/showthread.php?t=89983&page=96&p=1069049&highlight=Sunroof#post1069049
OMG Wayne, you have kids so probably have the tool to see if water can get out.....A water pistol (failing this a squeezy bottle)
Pull drain pipes off (like you did to shove the cable through) and at point blank, squirt water inside them and check if it gets outside. Have a cloth handy as you may just fill the pipe with water.
Thanks Stuart
I have a feeling its not the tubes - but water just sitting there (maybe dirt sat on the drain channels or something).
Water pistols?
U know how BIG todays water pistols are???? :lol:
Big, so make sure you video it, lol.
Lol
I going to wait a month.
Will be moving house soon (lose garage AND my backup daily :( :( :( )
So either going all out to find a replacement sunroof -
Or remove existing broken one and give all the rain channels a good clean!
SPOT the difference: Part 'bloody' troi :onfire::snipersmile::drinking::2gunfire::bad-words:
NEW light switch: OFF
NEW light switch: ON
OLD light switch: ON
Well
Car s starting to stall again :eek: :shocked!:
So did a scan (with engine off)
533: idle air control reg
537: oxygen sensor control
525: O2 sensor - voltage low
513: engine speed sensor - signal malfunction
Engine back on and...
No faults :thumbleft: :)
But thats becaused its not stall yet :shocked!:
Some good news (shocking!) :lol:
Car s not stalled (or tried to stall) since spraying some contact cleaner on the MAF plug :thumbleft:
:dance:
:clap:
:o
wet Wet WET !!! :eek:
At CCGB Stanford today :(
So
Good time to test my AngelWax H2GO rain repellant on windscreen :lol:
And thanks to another Corrado owner on the concourse,
He kindly lend me his alarm/immobiliser manual same model as mine (Scorpion 918 ) :thumbleft: :clap: :o
Edited by Wayne2015
