georgia1990 10 Posted February 11, 2015 so having issues getting a ticket on my car due to ABS light not coming on and going out with ignition. however, the fuse went for the ABS pump a while back and abs light stayed on solidly ( so i know it works when theres a fault present, just doesnt seem to do prelim checks). has anyone come up against this problem before as i got limited free time to get to the bottom of it. and yes the ABS does work i tested it on a wet road. if anyone could help, would be greatly appreciated.:thumbleft: Quote Share this post Link to post Share on other sites
Hairyarse 10 Posted February 11, 2015 Where in the UK are you Georgia? Maybe someone nearby has a code reader and can scan your car for fault codes? Quote Share this post Link to post Share on other sites
seanl82 23 Posted February 11, 2015 I have Giorgia. Turned out to be the fusebox to light loom, and the light itself was broken too. The pins on the light unit were loose where the solder had broken down on the pcb. Quote Share this post Link to post Share on other sites
georgia1990 10 Posted February 12, 2015 im in mid devon. Where in the UK are you Georgia? Maybe someone nearby has a code reader and can scan your car for fault codes? Quote Share this post Link to post Share on other sites
georgia1990 10 Posted February 12, 2015 the dash has been reinstalled badly from a heater matrix, so thats a good shout. il let you know what i find. cheers Quote Share this post Link to post Share on other sites
